2004 Power Stroke X
Old Jun 13, 2004 | 10:53 PM
Double JJ's Avatar
Double JJ
2004 Power Stroke X
I just purchased a new 2004 Excursion, the build date is 5/04, will this diesel engine have similiar problems as the earlier 03 / 04's I have since read about? I've never owned a truck or SUV before let alone a diesel. I bought the X because other than VW, this was the only available Diesel SUV. (Almost made a big mistake and bought the gas guzzling H2) I was amazed how high and safe I felt during the test drive. Here in Southern NJ, Diesel fuel is $1.59 a gallon compared to $2.29 a gallon for gas. Why is Diesel fuel so cheap in comparison to gas? Thanks.
Old Jun 14, 2004 | 12:45 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I'm not sure, but I think it's because you get to diesel before you get to gas in the refining process. Please correct me if I'm wrong.
Old Jun 14, 2004 | 07:57 AM
marspec's Avatar
marspec
Around here - West Virginia panhandle - diesel usually costs about 5 cents more in winter probably because diesel and heating oil are really the same.
As for diesel less than gas now I wouldn't be suprised if some of the reason for diesel costing less is political. I wonder how the streets of Washington, DC would look loaded with 18 wheelers if diesel prices rose as much as gas.
Old Jun 14, 2004 | 05:21 PM
psajunk's Avatar
psajunk
during the manufacturing process, you get more diesel fuel per barrel of crude than gas. Gasoline also has a more lengthy refinement process.
Old Jun 14, 2004 | 05:44 PM
cgl's Avatar
cgl
Maybe they should load the steets here in cali then! #2 is $2.37 87 is $2.39
Old Jun 14, 2004 | 07:40 PM
Double JJ's Avatar
Double JJ
Thanks, now it makes sense. One more question, can you use a remote starter on a diesel engine? Like I said, I'm new to diesel engines and appreciate any and all info.
Old Jun 14, 2004 | 08:32 PM
Toreador_Diesel
Sure you can. Ford as well as many other manufacturers make great security systems and remote starters. I'm thinking about getting one myself.
ANigrelli132
Jun 8, 2013 03:40 AM
NY Signman
Dec 18, 2005 09:27 PM
rmo1
Aug 25, 2005 10:20 PM
tstpnb
Nov 7, 2003 03:04 AM
