dash lights dont work
Old Jun 19, 2004 | 08:57 PM
77300i6's Avatar
77300i6
I don't know if I would swap a 300 six for a 302 V8. IMHO a 302 is worse than a 300. If you want a V8 I would get a 351W. More bang for the $. Hurst makes a universal 3 spd. shifter(indy they call it- I think). Also, if switching to a V8 I would also swap in a NP435 or a B.W. T-18 four spd.( lookin' at the 435 more) Both the the 302 and 351W use the 300 bellhousing bolt pattern-though you would need different engine mounts and a larger radiator. I was liucky enough to have a V8 radiator w/ my 300 six and you may be as well. Good luck w/ your project.
Old Jun 20, 2004 | 08:58 PM
wezol5484's Avatar
wezol5484
Yea I had the same problem, when I took mine out the back end crumbled apart. Since I was broke at the time, I used a little bit of JB weld to hold it temporarly. It might work for you too until you can find a new one but it depends on how big the pieces are that fell off of it.
js23
Feb 13, 2015 05:57 PM
tgreening
May 1, 2014 07:28 PM
slaseman
Dec 12, 2013 03:47 PM
jordan101
Mar 22, 2011 11:46 AM
77traded
Mar 27, 2005 06:57 PM
