clutch problems
Old Jun 13, 2004 | 06:17 PM
84ford4x4's Avatar
84ford4x4
clutch problems
hi i replaced my cab on my truck an clutch resurve was empty from fluid . guessing leaked out when it was setting . do i have to bleed the sectem or does it do it on its on . i have clutch it grabs not far from floor is this normal ?
Old Jun 14, 2004 | 12:10 PM
lmadore's Avatar
lmadore
If air got in the system, you will have to bleed it.
Old Jun 15, 2004 | 07:54 PM
84ford4x4's Avatar
84ford4x4
how do i bleed it where is the bleeder at ? reserve was empty so i would guess it got air in it
Old Jun 16, 2004 | 12:24 PM
lmadore's Avatar
lmadore
I've not worked with enough clutches to tell you, but chiltons and haynes should have info. I don't know how Ford clutches are setup, but there should be a bleed valve on the slave cylinder down near the transmission. Bleed is similar to brake bleeding.
1990fordf-250
Dec 21, 2014 05:41 PM
GUERILLA
May 8, 2009 09:20 AM
Dieseldan7.3
28
Apr 5, 2005 05:20 PM
fordmudrunner2020
Offroad & 4x4
Jan 27, 2005 06:30 PM
captbly
Apr 6, 2001 11:15 AM
