Clickety Clack
Old Jun 12, 2004 | 10:51 PM
rbdutton's Avatar
rbdutton
Clickety Clack
My 91 F250 7.3 has a slight miss, can hear a ticking sound with it running. Today I was going to change the valve cover gaskets and find the noise. While I had the cover on the right side off, I started it up. With the cover off, there is a loud kind of clacking sound at the front of the head. Cannot tell for sure if it is a metallic clacking noise or compression coming up somewhere in the vicinity of the front two valves. While poking around, I found a bit if metal, bronze or copper looking inside the front valve spring. Kind of a round almost tube shape. Any ideas will be appreciated. Also, can you put the cylinder at TDC and get the valve spring off without pulling the head?
Old Jun 13, 2004 | 01:46 PM
351M's Avatar
351M
Almost sounds like a valve guide is shot if you found a tube shaped peice in the valve spring.
Hellbore
18
May 22, 2006 03:10 PM
97EddieBauer
Apr 27, 2006 08:52 PM
JLinder2
Dec 13, 2005 02:39 PM
packrat56
15
Jun 20, 2004 02:59 AM
mkb1314
Oct 13, 2001 10:28 AM
