snowplow??
Old Jan 2, 2003 | 02:25 PM
justbrenda's Avatar
justbrenda
snowplow??
I have a 1995 Ford Explorer XLT 4 door. I'm wondering if I can put a snowplow on it. It would be for personal use not commercial. If yes, what does anyone recommend? If not, why? Thanks.
Brenda
Old Jan 2, 2003 | 03:07 PM
tw's Avatar
tw
snowplow??
First off, i think theyll move this to the explorer forum.
But to answer your question, i believe there are kits available for rangers/explorers.
I personally wouldnt recommend doing this if this is your daily driver. You will need to beef up your suspension to handle the added weight. This will be very uncomfortable in the many months that you dont have the blade attached. Im sure some will not agree with me, but the explorers and rangers were not meant for the abuse that a blade puts on a rig.
Just my 2 cents.
Tony Warren
Nebraska
03trueblue's Avatar
03trueblue
snowplow??
Try this place,
http://www.snowbear.com/html/snowplows.html
I bought one of these for my F-150. I works pretty good for my 1000' long driveway.
Old Jan 2, 2003 | 03:27 PM
Mil1ion's Avatar
Mil1ion
snowplow??
Moving thread to Explorer forum
Dennis
[i]F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/starfleet_command_e0.gif
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Jan 3, 2003 | 08:02 PM
brt's Avatar
brt
snowplow??
I've had 20+ years of plowing in vehicles ranging from "old style" Broncos to F-250 3/4 ton pickups. My advice is to use the Explorer for what it was designed for -- getting from point "A" to point "B". They were not designed to push Point A over to Point B. If you really want to get serious about plowing find a 3/4 ton or larger vehicle and have at it. Even if you have the right vehicle you can still break stuff if you aren't careful and try to bite off more than your vehicle can handle. If you have a short driveway a snowblower can do a great job and they come in various sizes. You can also put the snow exactly where you want it with a blower. I've had snowblowers as long as I've had plows and actually use the blowers more than the plow. The only thing that I miss when using the snow blower is that warm cab.
Old Jan 4, 2003 | 02:45 PM
CNTHOR's Avatar
CNTHOR
snowplow??
Don't do it, Your transmission won't hold up, even with a seperate cooler
Old Jan 7, 2003 | 10:41 AM
justbrenda's Avatar
justbrenda
snowplow??
Thanks to all for your advice...I have a 900' driveway and thought a snowplow on the Explorer would be a good idea...but from what I've read, it's not. My 17 hp lawn tractor with snowblower attachment works just fine. The few times I've had it plowed the mounds of snow just take up too much space and take forever to melt. The snowblower is just what I need.
Brenda
Old Jan 12, 2003 | 11:04 AM
wolfmanagh's Avatar
wolfmanagh
snowplow??
about 20 years ago my dad had got a wheel horse lawn tractor to blow the driveway. It was about the same size as yours. He said if he could do it again he would just get a used plow truck. You can spend around the same dollars for a lawnmower with the snowblower set up as you would for a used plow truck. Then it will take you more than an hour to clear that amount with a blower. The plus side of a used truck is you can use it for other things. Or as long as you don't take it of the property don't even worry about plates.
Old Jan 12, 2003 | 02:47 PM
tenlbr's Avatar
tenlbr
Post snowplow??
bmad50
May 11, 2014 02:27 AM
brendaf150
Oct 22, 2013 05:08 PM
thefarelaneman
18
Feb 13, 2007 07:21 PM
rikfish
Mar 29, 2004 09:11 AM
brenda
Electrical Systems/Wiring
Aug 8, 2000 11:37 PM
