429 vs 360 390
Originally Posted by RichardMaerz69
I was just trying to clear up some arguments,is thier any diferance in the heads,block,or crank on the 360,390 to the 429.
Just to add to the "you can or can't bore" thread. The "nominal" cylinder wall thickness is just that. What comes into play in real life is core shifting. In other words, as the cast iron block cools, it deforms. That's when "nominal" values go out the window.
That's why you can end up with one FE block that can be bored .080 but another one can't, because the cylinder wall thickness and spacing is not consistent between the cylinders. There was some amount of core shifting and the values are neither consistent or within nominal range.
Of course, such blocks were used because they did fall within nominal values for stock motors with a stock bore. Ford (or any other manufacturer) could have cared less about overboring. I believe you'll find that every manufacturer recommends .030 as the maximum overbore. In other words, be safe.
Originally Posted by neverenough
The D3TE means D=70 3=3 or 1973, T=truck, E=engine. The website store offers books to decode, otherwise, if you just have a couple of parts to decode, I'm sure someone in the respective engine forum could decode it for you. I can tell you, that code is not for a 385 series motor. Good luck.
Thanks for the helpful reply. I will go looking for a reference book.
Adrian
ReconAttitude
07-31-2013 05:55 PM
68 f250
19
03-27-2012 07:27 AM
justforkicks
01-21-2011 07:51 PM
71F250camper
15
05-02-2005 10:36 AM
DeenHylton
07-02-2002 12:56 AM
