Sponsored by: Real Truck
electric brake controller
Old Jun 11, 2004 | 11:57 AM
joedepilot's Avatar
joedepilot
going to install brake controller on my 2000 f250sd 5spd 5.4 4.10 will i need a heavy duty flasher or anything else? truck has addon class 3 hitch. not factory tow pkg.
Old Jun 11, 2004 | 12:23 PM
Twin Tritons's Avatar
Twin Tritons
What kind of loads do you plan on hauling? I am currently looking at proportional brake controllers. The Towing, Trailers, and Fifth Wheels forum in the Misc. section has some great info on brake controllers. Here's the link to the Proportional Brake Controller Thread
All my trucks were ordered with the towing package. I had to upgrade the flasher in my 1997 F-350, but my 2002 and 2004 trucks were fine. Don't know if this has to do with the newer super duties or the towing package.
Old Jun 11, 2004 | 12:53 PM
wlihntr's Avatar
wlihntr
if you truck has the towing package you should have a factory plug for a brake controller, so when you buy the controller you can get the plug from them so all you have to do is plug it in under the dash and pug it into the controller, its as simple as that,,now where is that plug you ask, open the panel under your steering wheel(4 big plastic screws, where the fuse box is)all the way to the right of that opening you will see a black plug next to a metal frame with some holes in it, behind the plug and on the other side of the metal frame(thru one of the holes) should be a gray open plug with silver pins in it, thats it.
oh sorry i did not catch that you dont have a factory tow package, take a look anyhow. on the window sticker of my '01 it does not list the tow package but i have the plug for the controller
Old Jun 11, 2004 | 02:20 PM
jasfaa's Avatar
jasfaa
I believe sometime in the late 90's they come pre-wired. I know the 2000 and up have them wired already....
Old Jun 11, 2004 | 06:12 PM
joedepilot's Avatar
joedepilot
i have the under dash plug and there is a plug a rear hitch. i will pull tandem axle trailer weighing up to 9000 #. the reason i ask about heavy duty flasher is that i see a couple of fuses? or flasher? in a plastic bag with the plug on an ebay oem kit.
Old Jun 11, 2004 | 06:13 PM
joedepilot's Avatar
joedepilot
will only tow this heavy <100 miles 2-3 times year.
Old Jun 11, 2004 | 06:23 PM
wlihntr's Avatar
wlihntr
the controller i got(tekonsha prodigy) came with the controller and the plug and that was it, i have not used it yet but from everthing i read you plug it in and go, no need for extra or bigger relays or fuses
Old Jun 13, 2004 | 11:36 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I use a Tekonsha Sentinal controler and it works great. I've used it for 5 or 6 years with no problems. On my 2000 the wiring was behind the computer access plug under the dash. No plug just wires,
Old Jun 13, 2004 | 12:23 PM
Edmo's Avatar
Edmo
I have the Tekonsha Prodigy and love it... It's versatility has worked great with our travel trailer from Anchorage to Orlando.
My 2001 SD came new with 2 relays, 2 fuses, and a wiring harness stuffed in a plastic bag. One relay and fuse is for the electric trailer brake wiring and the other set is for the trailer battery charge cable. They go into one of the electrical junction boxes under the hood.
The fuses do the obvious, while the relays open their respective circuits when the key is off to keep your truck's battery from being drained. The wiring harness mates to the brake controller's harness and then plugs into a cannon plug under the dash. It took me about 45 minutes to have it up & running.
My truck had the tow package (like most all SDs in 2001), so the controller was plug & play. My flasher was also HD and works great.
Does your truck have the round 7 pin trailer plug in the rear? If not, you will have to get one installed.
Edmo
Old Jun 13, 2004 | 09:57 PM
joedepilot's Avatar
joedepilot
that is what i seen in the plastic bag. is there a part number on the fuse or relay? I havent wired controller to the under dash plug yet. I have the 7 pim plug coming. joe
Old Jun 14, 2004 | 07:12 PM
wlihntr's Avatar
wlihntr
ok, i was wrong, after doing so research, and finding the trailer tow package in my tool box, after you plug in the controller you do have to put in 2 ,30 amp max fuses in the under hood fuse box #16,#28(the two empty ones) and put in two relays, in the little box right next to the main under hood fuse box
Old Jun 14, 2004 | 08:53 PM
joedepilot's Avatar
joedepilot
Smile
thanks for all the replys. you guys have solved and answered my problems. joe
