Info on adding Exhaust Brake
Old Aug 4, 1999 | 09:01 PM
Pete DuBose
Guest
Posts: n/a
I have a 99 F 350 Superduty SRW, 7.3 diesel and will be towing a 30' 5th wheel with a loaded weight of 13,800 lbs. The Rv clubs strongly suggest the addition of an exhaust brake.
Any experience with an exhaust brake such as US Gear or Pacbrake.
Ford is very vague on the warranty effects of adding any after market item.
Are you aware of the exh brake causing problems?
Old Aug 5, 1999 | 05:31 PM
Fred
Guest
Posts: n/a
I am not sure if there is an add on exh brake available for the t444e(PSD) motors. Although, if you can find someone who can program the existing one on your motor to work as a brake, then you may have something there. The EBP (on the turbo) blocks off the exh outlet from the turbo on cold starts to heat the cab quicker. I am not sure if it can be rigged in such a way.
I'd check with Navistar truck shops that use the same engine in larger trucks to see if they have it set up that way.
Old Aug 5, 1999 | 08:06 PM
Pete DuBose
Guest
Posts: n/a
>I am not sure if it
>way. I'd check with Navistar truck
>way.
Thanks for the responce. I understand the Pacbrake is installed at the turbo, however the US Gear exhaust brake is installed downstream on the exhaust pipe. USG calls it a D-Celerator and their web site is www.usgear.com
Old Aug 16, 1999 | 07:20 PM
zippo's Avatar
zippo
I was watching Shadetree mechanic the other day and they put a Jacob's engine brake on a Dodge. If one is also made for the Ford, I say go for it instead. That's what has been installed on every rig I have ever driven and never had a problem yet. Good Luck.
Old Aug 31, 1999 | 01:41 PM
Robert_1's Avatar
Robert_1
I have just purchased a F-350 7.3 liter. When at the dealer they handed me an accessory book that had the Jacob exhaust brake in it. I would call your local delear.
Robert
Old Sep 1, 1999 | 05:32 AM
Deen Hylton
Guest
Posts: n/a
Old Mar 19, 2005 | 06:34 AM
Backcountry Riders's Avatar
Backcountry Riders
Check-out BD exhaust brakes --this is the reason why we bought a diesel, to slow our rig down, we are very impressed with it's performance.
Old Mar 19, 2005 | 08:33 AM
Kwikkordead's Avatar
Kwikkordead
This must be find the really old thread week.
ccollins4680
Jan 25, 2012 10:08 AM
CO7.3PSD
May 19, 2009 02:47 PM
StanleyZ
Jan 28, 2009 02:55 PM
56jimmyno1
All Things Towing
Dec 15, 2007 07:41 PM
Irv
Jul 12, 2003 11:13 PM
