Alternator wiring - external regulator - got problem
Old Jun 10, 2004 | 01:56 PM
Valkyr's Avatar
Valkyr
I replaced the alternator ('91 E150, 302L V8) and took the old one to Autozone so I could be sure the replacement was correct. There's very little wiring because of the external regulator mounted above/behind the passenger-side headlight. The cable from the battery is no problem, but the clip with the small wire doesn't seat properly. Is this for the meter on the dash? Although the clip is set up for two wires, there's only one wire attached to it. The alternator has two spades sticking up. What are each of these for and why only one wire in the plug? Would a loose connection here make the gauge in the dash jump around? Sometimes the gauge reads all the way over to 'C' (charge), sometimes just below center line (towards discharge).
BTW, this issue is related to attempts to repair continuously discharging battery, especially when the lights are turned on. Already replaced battery, alternator, voltage regulator and starter solenoid. Suspect there is a short in the tail lights wiring somewhere because of intermittent operation of running lights.
Trying to keep the rusty beast running.
Thanks,
Joe V.
Old Jun 10, 2004 | 02:10 PM
Franklin2's Avatar
Franklin2
I checked the 1991 diagrams, and if it has an external regulator, the old standby wiring form the early years is still correct, though it has the idiot light wiring instead of the amp guage style wiring.
The lightgreen/red tells the alt to come online from the keyswitch.
The orange/lightblue tells the alt how much to charge
The yellow/white on the regulator tells the reg how much voltage is in the system, so it can tell the alt through the orange/lightblue how much output into the elec system.
Old Jun 10, 2004 | 07:46 PM
Valkyr's Avatar
Valkyr
Thanks for the information. I'll take a look at it again tomorrow, in between rain showers. I'll post results when I figure out what happened to the second wire (only one small wire in the plug connector now).
Joe V.
sunuvabug
Jun 22, 2024 01:58 PM
ryank59701
Electrical Systems/Wiring
15
Jun 14, 2019 10:32 PM
ryank59701
Oct 19, 2015 02:04 PM
Nitramjr
1997 - 2003 F150
Dec 17, 2012 11:43 AM
Alagator
May 28, 2003 06:52 PM
