Alternator not charging
Old May 28, 2003 | 10:58 AM
Alagator's Avatar
Alagator
Have a '78 Bronco that has had several issues. Engine was a 351M. Factory wiring, no add ons, etc.
The one issue I am dealing with now involves the Alt.
I have three wires going to the alternator, a larger gauge black wire, an orange wire with a boot, and a white (off white?) wire with a boot.
I assume the large gauge black wire with a ring lug goes to the BATT terminal on the alternator. It is actually pigtailed together with some other black wires further back. It appears to be a factory taped pigtail.
The other two wires (the orange and white) I assumed went to FLD and STA respectively, on the alternator.
Problem is that the ammeter (Charge/Discharge in dash) is constantly showing a slight discharge when engine is running. When lights or other accessories are ON, it further drops to the discharge side.
Have I hooked up something wrong? What does the white wire to the STA connection do?
Needless to say battery isn't getting charged.
HELP!
Old May 28, 2003 | 01:40 PM
Mil1ion's Avatar
Mil1ion
That's normal for Ford gauges.
(I think I'm the only in this world that has a working ammeter).
Voltage Regulator kick in is a around 850 rpm.
What you have to do to have piece of mind, is to get an idea with a Multi-meter to the battery when the engine is running.
You can do tests with different accessories (Heater motor,Wipers & Headlights) on & off.
Justa simple rev of the engine will so a charge condition.
Old May 28, 2003 | 01:56 PM
macguyver's Avatar
macguyver
The white wire goes from the alternator to feed the electric choke heater. It won't affect charging. Sounds like you've got it hooked up right but it isn't charging. Check for voltage on the field wire. The regulator supplies current on that wire to energize the alternator. Could be the regulator or a connection if there isn't any voltage on the field wire.
It appears your ammeter is working. The ammeter on my parts truck works but doesn't on any of my others. Count your blessings.
Old May 28, 2003 | 02:04 PM
Franklin2's Avatar
Franklin2
Old May 28, 2003 | 06:52 PM
Alagator's Avatar
Alagator
You guys are great. It was the regulator.
Really appreciate this board, 'cause someone always responds.
Thanks again.
F350dog
21
Dec 23, 2015 05:37 PM
augustjames
Electrical Systems/Wiring
Apr 7, 2014 06:46 PM
fourbangerford
Jan 8, 2014 05:51 AM
4drf350
1966 - 1977 Early Broncos
Jan 21, 2012 06:47 PM
Burner
Sep 4, 2005 09:12 PM
