am I safe?
Old Jun 9, 2004 | 09:16 PM
deekon's Avatar
deekon
Trailering
am I safe?
My 98 F150 XL has the following on tag on the valve cover:
2-14-98
396 372 317
Essex Engine Windsor
8K703DA
Should I still worry about the gasket failures?
I have 95,000 miles on it
Your response is appreciated
Thanks
Deekon
Old Jun 9, 2004 | 09:20 PM
pops_91710's Avatar
pops_91710
I have no clue what you are referring to. With 95K on the engine what gaskets are going to fail that already have not? What engine do you have?
Old Jun 9, 2004 | 09:24 PM
deekon's Avatar
deekon
Trailering
the lower intake gasket and timing cover gasket that the 97 have problems with leaking antifreeze into the oil.
If I read the leakingfords.com correct, it said engines made thru january of 98.
Old Jun 9, 2004 | 10:40 PM
BrianA's Avatar
BrianA
I'd contact your local Ford dealer and give them the build date. They should be able to tell you.
Old Jun 11, 2004 | 04:29 AM
BlueOvalFitter's Avatar
BlueOvalFitter
www.leakingfords.com
www.flatratetech.com
Gevans17
May 4, 2011 12:40 PM
exp1998
Jul 7, 2009 09:02 PM
rrumba
Jun 8, 2009 11:32 PM
namdorf
19
Apr 14, 2008 04:02 PM
Scottnascar
Modular V8 (4.6L, 5.4L)
Nov 27, 2006 09:51 PM
