1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Parking Brake Adjustment on 2000 Expedition
Old 06-09-2004, 06:09 PM
kangg's Avatar
kangg
kangg is offline
Question Parking Brake Adjustment on 2000 Expedition
Hi. I have a 2000 XLT expedition. Does not have air ride suspension. I noticed that I have to push the Parking brake further down in order for it to work. Does anyone know how to adjust the parking brake. I looked in the Chilton Manual and it says its self adjusting. Dealer told me that you can manually adjust it. They weren't helpful in telling me how to do it.
Old 06-09-2004, 06:33 PM
fmtrvt's Avatar
fmtrvt
fmtrvt is offline
The vehicle has disc brakes in the rear, but does utilize a DIH (Drum In Hat) parking brake. The cables no longer have a provision for taking up cable slack. This is done automatically in the pedal assembly. However, the DIH brake still has an adjusting screw for taking up clearance.
I'm going to talk in generalities, as for the life of me I can't remember exactly with your version. There usually is a rubber plug in the backing plate of the DIH. When you pull it out, you will have access to the adjustment screw. Usually only a few notches have to be turned, but you want to expand the shoes out so there is close contact, but no major drag on the wheel. To do that, the rear wheels should be off the ground and the vehicle in neutral. Under this situation, it's best to have a wheel chock or block on both sides of the front wheel so the vehicle does not roll. If you go too far, just back the screw the opposite way.
Here is a picture of what it looks like, but this is from an F-350.
Old 06-09-2004, 06:45 PM
2000Expy's Avatar
2000Expy
2000Expy is offline
Post parking brake adjustment
Hi,
From what I could gather in looking at the Ford Service Manual on CD, there is an adjuster inside the area containing the parking brake shoes. That is, remove rear wheels and parking brake drums.
Old 06-10-2004, 12:12 AM
kangg's Avatar
kangg
kangg is offline
thanks for your help. I could not open up the pic. Is there anything in particular I need to do.
Old 06-10-2004, 06:08 AM
fmtrvt's Avatar
fmtrvt
fmtrvt is offline
The picture just showed the screw in the assembly. Just pull the plug and just either a drum brake adjusting lever, or a flat blade screwdriver to move the star wheel.
Old 01-07-2013, 05:28 PM
aearch's Avatar
aearch
aearch is offline
emeg brake
this is JUST PLANE PPOOOOOOOORRRRRRRR
ENGINEERING EVER SINGLE ONE FAILS
EVEN IF YOU PUT NEW SHOES AND ADJUST TO
THE EXACT POSITION
IT WILL NOT HOLD THE DEALER SAID PUT A BRICK UNDER THE WHEEL
they are too small to hold the weight of the vehicle
the cable is the problem -it stretches out
the only thing to do is shortern the link under the
drivers door but then they drag its a very bad design
bill11012
1999 to 2016 Super Duty
31
08-05-2019 11:52 AM
Billy D. Scott
08-29-2016 01:11 PM
drielle
26
01-22-2016 03:13 PM
jhva
20
08-05-2009 08:12 PM
skeeter4x4
02-16-2006 12:47 AM
Quick Reply: Parking Brake Adjustment on 2000 Expedition
