Parking Brake Adjustment on 2000 Expedition
Hi. I have a 2000 XLT expedition. Does not have air ride suspension. I noticed that I have to push the Parking brake further down in order for it to work. Does anyone know how to adjust the parking brake. I looked in the Chilton Manual and it says its self adjusting. Dealer told me that you can manually adjust it. They weren't helpful in telling me how to do it.
The vehicle has disc brakes in the rear, but does utilize a DIH (Drum In Hat) parking brake. The cables no longer have a provision for taking up cable slack. This is done automatically in the pedal assembly. However, the DIH brake still has an adjusting screw for taking up clearance.
I'm going to talk in generalities, as for the life of me I can't remember exactly with your version. There usually is a rubber plug in the backing plate of the DIH. When you pull it out, you will have access to the adjustment screw. Usually only a few notches have to be turned, but you want to expand the shoes out so there is close contact, but no major drag on the wheel. To do that, the rear wheels should be off the ground and the vehicle in neutral. Under this situation, it's best to have a wheel chock or block on both sides of the front wheel so the vehicle does not roll. If you go too far, just back the screw the opposite way. Here is a picture of what it looks like, but this is from an F-350. Picture |
parking brake adjustment
Hi,
From what I could gather in looking at the Ford Service Manual on CD, there is an adjuster inside the area containing the parking brake shoes. That is, remove rear wheels and parking brake drums. :-hair :-X22 |
thanks for your help. I could not open up the pic. Is there anything in particular I need to do.
The picture just showed the screw in the assembly. Just pull the plug and just either a drum brake adjusting lever, or a flat blade screwdriver to move the star wheel.
emeg brake
this is JUST PLANE PPOOOOOOOORRRRRRRR
ENGINEERING EVER SINGLE ONE FAILS EVEN IF YOU PUT NEW SHOES AND ADJUST TO THE EXACT POSITION IT WILL NOT HOLD THE DEALER SAID PUT A BRICK UNDER THE WHEEL they are too small to hold the weight of the vehicle the cable is the problem -it stretches out the only thing to do is shortern the link under the drivers door but then they drag its a very bad design |
