Transmission Problem - I need help
Old Jan 25, 2000 | 06:54 PM
DaveClouse's Avatar
DaveClouse
I have a 1995 1 ton Ford Crewcab Duley, with a 7.3 powerstroke diesel, with a E40D electronic shift diesel equipt transmission. When it shifts from 1st gear to 2nd, it will run about 4 feet in 2nd gear, then downshift into first wihile sill in 2nd gear. If you let off the throttle, it will shift out of 2nd gear back into 1st immediately. If you press down on the throttle again, it will shift into 2nd and start the same process again.. What can be causing the problem? Transmission has just been rebuilt 1/23/00. Transmission worked fine for two days before the problem developed. I need help!
Old Feb 20, 2000 | 11:23 AM
whd507's Avatar
whd507
try disconnecting the battery cables and then re-connecting them and then go for a 10 minute drive to let the trans re-learn your driving style. if this does not work then you have a trans or computer problem.
Old Feb 20, 2000 | 07:35 PM
clapoi3426's Avatar
clapoi3426
fsaburro
22
May 20, 2023 08:10 PM
bphirt1
Dec 12, 2015 06:54 AM
annaleigh
Nov 11, 2015 11:57 PM
anthonym92
37
Apr 6, 2015 07:49 PM
VitaminD
Jan 25, 2012 08:09 AM
