Title change: Steering column inter-change
Old Jun 8, 2004 | 09:35 PM
johngemmer's Avatar
johngemmer
Unhappy Title change: Steering column inter-change
Ive got a ford F 350 the steering colunbshifter lever striped out what I need to know is will a 69 f 280 colum inter change with the 74 I dont want to pull it out it wont work please help I need my truck
Old Jun 8, 2004 | 11:00 PM
Nod's Avatar
Nod
Shift collar
johngemmer,I just put a new shift collar on my 73 F-350 SCS.It looks exactly like the one I put in my 72 F-250 a couple of years ago,they were both automatics(C-6).I don't know much about the three speed shift collars on the tree,mabey someone else will know in case that is what you are asking for.As far as I know the shift collars for autos was the same for the 67-72 models,I think the only thing that changed on the 73-79 shift collars was the addition of the emergency flasher switch to the collar assembly,but I may be wrong,good luck.
"bowties in the rearview mirror" PS. make sure you pull the park neutral switch tang on the inner collar shaft or you will break it off like I did when replacing the shift collar!!
Old Jun 9, 2004 | 04:19 AM
johngemmer's Avatar
johngemmer
thanks Im going to be useing the hole column the neutral safty switch dose not matter the one on the 69 has ben bye passed I will be putting in a quick silver in shortly there after once again thanks for your imput I have had three other say the same thing you said
69 f-100 aman
May 7, 2014 06:13 PM
trailriderbill
Mar 11, 2013 07:51 AM
meteorman
Apr 29, 2008 10:22 PM
jirikj
Nov 2, 2006 08:09 AM
Seabeetough
Mar 21, 2003 04:02 PM
