Horse Trailer Weight Question
Old Jun 8, 2004 | 05:13 PM
mrc59's Avatar
mrc59
I'm casually looking at horse trailers with LQs to fulfill a retirement dream. I have an F-350 SWR Auto SC 4X4 PSD LB that I thought could pull nearly anything I see behind a superduty and can afford .
Turns out that the max trailer weight listed in the owner's manual is 12500# with a GCWR of 20000#. Doing the calculations and reading lots of "how to tow safely" info tells me that I really need to know the empty and typical wet weight of any trailer I consider. A couple 1200# horses cuts into max weights very quickly.
I can't find much about weights on trailer manufacture sites. Is this number a trade secret? Too variable to publish? What am I missing?
Old Jun 10, 2004 | 09:28 AM
MrBSS's Avatar
MrBSS
I have had your problem with both trucks and trailers. Everybody talks about gross weight, but you don't know what you can add if you don't know the net (unloaded) weight. Where "curb weights" are available, they seem to be very approximate, depending on options, and unrealistically low even at that.
Only real solution I've found is to actually weigh the item in question.
Another question is, what happens if we ARE slightly overweight. I know we shouldn't go there, but obviously the axle doesn't turn to peanut butter for 10 extra pounds. If that axle would normally last in effect, forever, do we now accept that it wears out at 200,000 miles?
Make your best estimate, try to eliminate the shock-type stresses, maintain everything well, and don't lose any sleep!
Old Jun 10, 2004 | 10:52 AM
mrc59's Avatar
mrc59
Thanks much for the insight. Since this doesn't appear to be confined to particular makers, it must be a wide-spread practice. Silly too. I'd be tempted to choose a trailer solely on the ability to get an accurate curb weight.
Old Jun 13, 2004 | 03:33 PM
kcgold's Avatar
kcgold
you can call or e-mail most of the horse trailer manufacturers and they will tell you what the (approx.) dry weight of the trailer is. (for example, I recently looked a a big one which had a 28 foot box, or about 36' overall and the dry weight was about 6700 pounds). Living quarters usually add about 250 pounds per foot, measured on the shortwall if its a slant load...so a 13' LQ would add about 3200 pounds.
Hope that helps....
Kathy
Old Jun 13, 2004 | 04:10 PM
mrc59's Avatar
mrc59
Originally Posted by kcgold
snip... Hope that helps....
Kathy
Indeed it does. Welcome to FTE!
Old Jun 13, 2004 | 08:34 PM
kcgold's Avatar
kcgold
thanks!
forgot to add that there is a very helpful forum on Horse Trailers online...nice folks who can answer almost everthing over there to do with trailers and towing them:
www.horsetrailers-online.com
Kathy
flyinnuts
2009 - 2014 F150
Aug 4, 2011 03:48 PM
Country Gal
All Things Towing
34
May 18, 2010 11:24 PM
Chris89lx
All Things Towing
18
Mar 27, 2009 04:12 PM
Ibby
All Things Towing
May 3, 2006 09:41 PM
moebdick
All Things Towing
Oct 12, 2004 04:15 PM
