Tire/towing question
Old Jun 10, 2004 | 08:09 PM
SHartman's Avatar
SHartman
I have a 97 PSD, LWB, SRW, automatic trans. with the camper package. My boss asked me if I would be willing to put a fifth wheel hitch on the truck so I could begin towing a 10,000 lb trailer we just acquired. I know the truck should handle the weight with no problem, but I need new tires and had been considering going up to a 285/75 from the 245's that are on there now. How would the larger tires affect the towability of this set up? Is the single rear wheels ok or should we be using a dually to pull this rig? Thanks in advance.
Old Jun 11, 2004 | 09:33 PM
Steina's Avatar
Steina
CO River Rat
Is your boss sure about the weight of that trailer, or is it a "guesstimate"? Until you have the trailer weighed, you have no idea what you're getting into. Once you've got accurate weights of the trailer and on the hitch, then you can start planning accordingly. Good luck!!!
Steve
Old Jun 11, 2004 | 10:05 PM
peppy's Avatar
peppy
Not sure if the size increase would offer more stability. It may even produce some extra roll. http://www.tirerack.com/index.jsp
I have plenty of experiance with the GoodYear Wrangler HT and I have nothing but good things to say. With 15 years fire/ems....I've abused these tires in many ways. Another good choice is the Michelin LTX A/S, which is available in load range E, gets you a couple extra belts in there. I've had these on a couple ambulances with no complaints.
My towing experience is quite limited.....but my abusive history with tires is a little lenghty.
Old Jun 11, 2004 | 10:31 PM
rclarke's Avatar
rclarke
The 1997 towing guide lists towing capacities from 9400lbs to 14,000lbs depending on rear end ratio and body style. Oversize tires will lower the ratio of the rear end and lower the tow capacity. I also would think oversize tires might reduce the stability.
Old Jun 11, 2004 | 10:32 PM
SHartman's Avatar
SHartman
Steve
yes I know the exact weight of the trailer, 9,987 lbs. It is a mobile air quality laboratory that I operated for the last ten years of the 30 I spent with my previous company.
I guess my question is how will the larger diameter tires affect low end torque and is the single rear wheel sufficient? I also forgot to mention the truck is an F350 with 3.55 rear gears.
Old Jun 12, 2004 | 12:04 AM
Steina's Avatar
Steina
CO River Rat
I think the 3.55 rear gears are going to be marginal at best. Like rclarke wrote, larger diameter tires will only make it worse. Again, do you know how much weight the trailer is going to place on the hitch if you install one?
Steve
Old Jun 13, 2004 | 07:44 PM
rclarke's Avatar
rclarke
If that truck has 3.55 gears you are going to be closer to maximun capacity than I would want to be. The 1997 Towing Guide lists 16,000lbs as gcwr and 10,500lbs as maximum tow with 4x2 and 9900lbs maximum with 4x4. I believe the weight of the truck will be over 6000lbs leaving less than 10,000lbs for any load, driver and trailer. Also the trailer at nearly 10,000lbs should have at least 2000lbs on the hitch, possibly going over the rear axle capacity.
Conclusion----I don't think you will be happy towing this heavy a load.
Old Jun 14, 2004 | 12:20 AM
psdpower's Avatar
psdpower
The larger tire may kill a little lowend but a 285/75/16 is barely taller then the stock 235/85/16, so I don't think it will make a very noticable difference. The wider tire should increase stability with it's wider contact patch. Just be sure to get load range E tires in whatever size you decide on, load range D tires would be very overloaded with that trailer.
cw_mi
Nov 12, 2014 08:32 AM
Don Weismantel
Jul 12, 2012 10:21 AM
Cam_Man595
Nov 13, 2011 05:58 PM
PEI
Jul 24, 2010 05:34 AM
NoBite
All Things Towing
20
Jul 9, 2007 09:20 AM
