a little help plea
Old Jun 8, 2004 | 01:20 PM
pman621's Avatar
pman621
Question a little help plea
if anyone has an idea of where i can get a diagram of the cooling and radiator and hoses for a 1986 f-150 with a 5.0 litre engine, please let me know. this truck had an engine swap before i got it, and i'm having a problem getting the hoses corrected. thanks for any help.
Old Jun 8, 2004 | 04:46 PM
andym's Avatar
andym
There should be a lower radiator hose, an upper radiator hose, and two heater core hoses.
What problem are you having?
Old Jun 8, 2004 | 06:42 PM
bigbrown84truck's Avatar
bigbrown84truck
don't forget about the tranny cooler lines comming off the radiator as well if it is automatic.you should be able to go into a parts store and buy the upper and lower hose preformed to fit proper for your truck.
Old Jun 8, 2004 | 07:19 PM
Nightrain's Avatar
Nightrain
I don't know about buying the heater hoses right off the shelf. Most of the time they have to know the size and also the lenght. I don't know anything about a diagram, and if I had a 5.0L, I would take some pics. I'll check around and see what I can find pman621 .
Nightrain
Old Jun 8, 2004 | 09:46 PM
pman621's Avatar
pman621
the guy that i got this truck from, had a t hooked to the heater core hoses. he the attached that to the intake plenum, is this where it's supposed to be hooked?
Old Jun 9, 2004 | 12:42 AM
bigbrown84truck
nightrain, i know you can't buy heater hose in premade peices but you can get upper and lower hose that way, infact your supposed to. Now pman621 for the heater hose routing, i am confused by what you said, but it should only be two hoses. and both go to the heater core, one takes the anti-freeze to the core and the other is the return. this why if you heater core goes out you can just take one of the hoses and bypass the heater core.
Old Jun 9, 2004 | 08:35 AM
Nightrain's Avatar
Nightrain
Yeah, I know that you can buy the radiator hoses premade. I was just letting him know on the heater core hoses so he's prepared if he has to buy new ones .
Nightrain
Old Jun 9, 2004 | 09:52 AM
Oscar Meier's Avatar
Oscar Meier
It sounds like the other engine had a heated intake manifold or carb plate - that's what the tee was for in the heater hose.
If you no longer have the heated manifold or carb plate, you can eliminate the tee and do the standard connection from the engine to the heater core.
Old Jun 9, 2004 | 11:50 AM
RL_F150's Avatar
RL_F150
Hi pman621,
I have a 1985 F-150 with the 5.0L engine. I also have some pictures of the engine that might be able to help you.
Rather than kill the page loading time, I'll post the pictures as links. I added red dashes to emphasize where the hoses are in a couple of the photos...probably overkill.
Upper Hose:
http://homepage.mac.com/rlemons/truckpics/Engine1.jpg
Lower Hose and Overflow Bottle Hose:
http://homepage.mac.com/rlemons/truckpics/Engine2.jpg
Upper Hose and Heater Box/Hoses:
http://homepage.mac.com/rlemons/truckpics/Engine3.jpg
Better View of Heater Hoses/Upper Hose:
http://homepage.mac.com/rlemons/truckpics/Engine5.jpg
Heater Hose/Bypass Hose on Water Pump:
http://homepage.mac.com/rlemons/truckpics/Engine7.jpg
One of the heater hoses has a connection almost directly under the EGR and throttle body. This is indicated by the arrow in "Engine5.jpg".
Hope that helps!
Old Jun 9, 2004 | 07:07 PM
pman621's Avatar
pman621
the guy that did the engine switch, hooked a tee in the heater core hoses. he then hooked it the upper intake plenum, why i don't know. is this susposed to be there is my main question?
Old Jun 9, 2004 | 07:34 PM
lmadore's Avatar
lmadore
I've got an 86 w/ a 5.0 that is all original.
There is a Tee in one of the heater hoses the has a small 5/8" dia. hose attached to it that leads to a connection on the Throttle body. The coolant then leave the throttle bottle at another connection and is connected to the lower intake manifold at the same place that the bypass hose is connected.
This was done to heat the intake air charge. These motors don't utilize an Air charge temperature sensor (ACT). Ford Engineers just opted to heat the intake. My guess is that this would cause a quicker warm-up when the air is cold. It probably resulted in lower emissions sooner during the engine warm-up. Similar idea to the preheater hose on a carbed engine that pulled air across the exhaust manifold before going to the carb during cold starts
jake_whitman
24
Jan 2, 2015 05:51 PM
Pete Kildow
Large Truck
Nov 5, 2013 10:19 PM
dawhits1
Jan 9, 2011 07:05 PM
fatherdoug
3.0L V6
Jan 27, 2004 08:06 AM
donb_1
1983 - 2012 Ranger & B-Series
Feb 8, 2000 12:49 AM
