Unknown hose
Old Jan 1, 2015 | 10:47 AM
jake_whitman's Avatar
jake_whitman
Unknown hose
I was pulling my spark plugs yesterday and accidentally ripped a hose that goes from the air filter housing down to a cylinder that sits just above the frame. Does anyone know what this hose is or what it does? I'll post pictures tonight when I get home. Also I'm not exactly sure what happened but after I put the spark plugs back in it now the engine makes a faint ticking noise when I get on the gas. Could this be the hose or something else? I have a 72 f100 with a 360. Thanks for all the help!
Old Jan 1, 2015 | 11:30 AM
BobbyFord's Avatar
BobbyFord
If you're referring to a paper-like hose that goes down to a charcoal canister (9D653) on the right front frame rail, it is part of the emissions system for a vented fuel tank.
http://www.fordification.com/tech/im...cab-w-evap.jpg
Old Jan 1, 2015 | 11:45 AM
HIO Silver's Avatar
HIO Silver
NAPA #BK825-4025....3/4" X 36" Preheater hose.
Old Jan 1, 2015 | 11:58 AM
jake_whitman
I'm fairly positive this is the hose. Would it cause a ticking noise if opened up?
Old Jan 1, 2015 | 12:11 PM
BobbyFord's Avatar
BobbyFord
No. No sound at all. It vents fuel vapor from the fuel tank, through the charcoal canister and then gets recycled into the air cleaner. It's just a vent hose.
Old Jan 1, 2015 | 01:40 PM
RichS2659's Avatar
RichS2659
Ah, grasshopper. You have a loose sparkplug. Take out and retighten them, or they will come blasting out over your head. I have experience with this.
Old Jan 1, 2015 | 05:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If you're referring to a paper-like hose that goes down to a charcoal canister (9D653) on the right front frame rail...
It is part of the evaporative emissions system (Evap/Em) for a non vented fuel tank.
Evap/Em: Non vented fuel cap, unleaded gas. The fuel filler tube(s) and the fuel tank(s) used with Evap/Em are also different.
Evap/Em introduced in 1970, was installed initially in 1970/72: Passenger Cars/Bronco's/Econolines & F100's all sold new in CA .. Other states may have required it as well.
With Evap/Em, there is a fuel vapor valve located in the tank(s), vapor line(s) routes along the right frame rail to a valve on the charcoal canister located under the hood.
A corrugated (factory) paper hose routes from this valve to an elbow on the air cleaner. HIO's pic shows the auto parts store replacement hose, the original was black.
Old Jan 1, 2015 | 05:34 PM
BobbyFord's Avatar
BobbyFord
You're a little backwards there, Bill
Vented tank uses a non-vented cap.
Non-vented tank uses a vented cap.
Old Jan 1, 2015 | 05:52 PM
NumberDummy
Vented tank uses a non-vented cap. Non-vented tank uses a vented cap.
Who is starting the New Year off bassackwards? You are, kiddo.
Evaporative Emission uses a 4 'eared' non vented fuel cap, the fuel filler tubes are specific to this type of cap, unleaded gas is required.
No Evaporative Emission, the fuel cap is vented and has 2 'ears' on it, no unleaded fuel required.
There is no vent on the 1961/77 in-cab tanks, so it's muy importante that one uses the correct fuel cap. Optional auxiliary tanks might have a vent, might not if Evaporative Emission is in place.
And, the auxiliary tanks with Evaporative Emission are smaller than the non Evaporative Emission tanks (1967/72: 22.5 gallons vs 25 gallons).
Old Jan 1, 2015 | 05:57 PM
BobbyFord's Avatar
BobbyFord
Evaporative Emission uses a 4 'eared' non vented fuel cap, the fuel filler tubes are specific to this type of cap, the tanks are non vented, unleaded gas is required.
There is no vent on the in-cab tanks, so it's muy importante that one uses the correct fuel cap.
We're saying the same thing.
Ev/em tank is a vented tank. Venting to the charcoal canister. Ev/em tank uses a non-vented cap.
Non-Ev/em tank (sans canister) is not vented and requires the use of a vented cap.
Old Jan 1, 2015 | 06:14 PM
NumberDummy
Not the way I read your responses, we weren't.
Ev/em tank is a vented tank = venting to the charcoal canister. Ev/em tank uses a non-vented cap.
You got it right this time. I was all ready with a pic to prove you wrong, but figured what the hell, I'll post it anyway for the "doubting Thomases."
D1PZ-9030-K & D1UZ-9030-A .. Fuel Caps non vented-Use with Evaporative Emission.
Old Jan 1, 2015 | 06:20 PM
BobbyFord's Avatar
BobbyFord
You got it right this time. I was already with a pic, but figured what the hell, I'll post it anyway for the doubting Thomases.
We were on the same page but equally confused
Old Jan 2, 2015 | 12:54 PM
JEFFFAFA's Avatar
JEFFFAFA
Ha Ha. Kinda like one saying tomaato and one saying tomahto.
Old Jan 2, 2015 | 12:56 PM
HIO Silver's Avatar
HIO Silver
.. more like one saying it's less negative and the other stating it is more positive.
Old Jan 2, 2015 | 02:18 PM
NumberDummy
Do y'all recall when Dan Quayle (George H. W. Bush VP), while attending a grade school spelling bee...misspelled potato as potatoe?
He was ridiculed by the news media for this gaffe.
