MAF conversion for a 408
Old Jun 7, 2004 | 10:29 PM
frdboy's Avatar
frdboy
I am doing a 408w for a customer and I am going to convert it to maf.
Can I use the frpp kit for the lightning. It is a 95 with a E4OD.
Thanks
Adam
Old Jun 8, 2004 | 02:52 PM
EPNCSU2006's Avatar
EPNCSU2006
The electronics I believe would be fine, but you'll have to get a different air intake hose since the lightning only has a single pipe.
Old Jun 8, 2004 | 03:21 PM
frdboy's Avatar
frdboy
Cool thanks, I think I will try it.
Old Jun 12, 2004 | 06:18 AM
rjlougee's Avatar
rjlougee
Does the engine have the GT-40/Lightning intake on it? IF so, then no problem. If it has the truck style intake then you're going to need to order the MF to TB air tube from a '96 CA 5.8 so you can use the MAF meter with the twin truck TB.
You're also going to run out of injector with the 408W if you're still running the stock 19# units. If not, then you've also got the added $$ for the bigger injectors and MAF.
There are other ways to run it, which may be better depending on your electrical wiring comfort level.
Joe
Old Jun 13, 2004 | 05:52 PM
frdboy's Avatar
frdboy
Hey Joe,
Thanks for the info, it will have the truck intake from edelbrock so I will order that intake hose assy.
One of the reasons I wanted to rum the Ford set-up is because it comes with 30lb injectors and a 80 MM MAF.
If it was my truck I would build/wire the MAF conversion myself, but this is a customers truck and we are on a tight time schedule.
Thanks Again
Adam
Old Jun 14, 2004 | 06:09 PM
Kemicalburns's Avatar
Kemicalburns
you gonna get this truck dyno tuned? if so post some #'s
Old Jun 14, 2004 | 08:35 PM
frdboy's Avatar
frdboy
Most likley it will be dyno tuned and I will post the numbers.
Thanks
Adam
andyort
Engine Swaps
30
Mar 5, 2017 03:53 PM
BRay09
13
Oct 21, 2015 08:27 AM
crashmaster79
May 10, 2015 10:20 AM
bluepartsman
WTB - Parts & other
Sep 8, 2014 07:36 PM
wayneF250
19
Aug 31, 2008 10:03 PM
