ac for 65 f100
Old Jun 6, 2004 | 06:44 PM
kf4zqw's Avatar
kf4zqw
ac for 65 f100
Dose anyone know where i could find a ac unit for my 65 f100?
also im looking for both cab doors.
thanks.
david
Old Jun 6, 2004 | 10:23 PM
dusty64f100's Avatar
dusty64f100
for the ac try http://www.air-tique.com/selection.htm
Old Jun 7, 2004 | 06:25 AM
William's Avatar
William
Fitment of the condenser and the pullies will drive you nuts! There are a couple of things you need to decide before you start. Will you use the original heater and defrost with an under the dash (hanging) AC unit. Do you plan to use the Ford type compressor. I would use a Sanden compressor, R-134 and a hanging AC unit. I like the 60's look and there are plenty of nice looking hanging units. This setup is the least expensive and easiest to install in the cab. The Sanden compressors are the easiest to mount and least expensive to operate. Ford drive pullies are a royal PITA! If you have a FE motor there is York compressor adapter that uses the Ford bracket and adapter to mount the Sanden compressor. This is the setup I currently have and it really works nice. Mounting the condenser requires shimming the radiator back about an inch and you need to consider fan to radiator clearance when you do this. I bought a shorter fan clutch and used a plastic shroud from a later F100 (76 I believe). The hood release will contact the condenser and will require modification. Several companies will sell you a complete system for about 800 bucks. Good luck and let us know what you decide.
Old Jun 7, 2004 | 08:10 AM
kf4zqw's Avatar
kf4zqw
thanks guys for the info.William i think im going with the hamging unit.try and stay with a 60s look! im new to this so all the info i can get is welcomed very much.the motor is a 74 302 with a c6 and 273 gears.made for the hwy.ill let you know how things go.disc brakes and ac are a must! mostly the ac,need it bad here in florida..lol again thanks and i will keep you up to date.
my email is kf4zqw@yahoo.com
David
Old Jun 9, 2004 | 10:26 PM
CustomCab4x4's Avatar
CustomCab4x4
David, Classic Auto Air in Tampa can fix you up with about anything you'd need. Might give them a call. ?? Later, Phil
Classic Auto Air in Tampa, Fl.at 813-251-2356 or
813-251-4994.
Old Jun 10, 2004 | 07:28 PM
kf4zqw's Avatar
kf4zqw
thanks phil.ill give the a buzz and let you know what i find out.
Old Jun 10, 2004 | 08:10 PM
banjopicker66's Avatar
banjopicker66
One of the easiest ways to get the parts you need is to find a 302 motor with the brackets and pulleys you need. I understand there are different years of interchangeability on 302s, so get that information first to establish the correct range of years which will be compatible with your '74.
Then, scour the papers and the boneyards for a parts car or parts truck with the complete set of pulleys and brackets, and use those for your truck. It doens't have to run, and can be wrecked - and that's better for you, since you can get it cheaper that way to strip it for everything useable.
Ford had a habit of using the same motor for a variety of applications, but with different bracket and pulley setups depending on what the engine went into. So, get yourself a '73 - '79 parts truck with a 302 and A/C, or a parts car like a Lincoln, T-bid, or whatever, just make sure it is complete, and compatible with your engine and truck setup.
This way, you get a complete setup, and don't have to chase a lot of parts. Or worse, waste a lot of money on an incomplete set.
This is exactly what I did. I found a '76 with PS, PDB, and A/C, with the same motor as my '66. I put the '76 pulleys and brackets on my '66 engine, Used a condensor from a '74 LTD (had to set the radiator back, and make a bracket for it), had a hanging unit from the boneyard, and had all new lines custom made. Works great, and still works geat 20 years later.
Then, I sold the parts off the truck I didn't need, and got a lot of money back.
I'll put the PDB on later.
Old Jun 10, 2004 | 10:02 PM
kf4zqw's Avatar
kf4zqw
thanks banjopicker! i found a boneyard close by,hard to find one in this town..any way on my next day off im going to hit and look for some some partsive had this truck for 18 years and im the second owner.the 65 is kind of speacil becouse it was the last thing my dad and worked on before he past away from cancer.so all the help i get on here is greatly welcome.the 302 came out of a station wagon best i can remember is was a ltd.lol c6 is from a 78 van.now lets see what i get for the a.c. and disc brakes! got to love this hobby!!!!
Old Jun 11, 2004 | 12:11 AM
CustomCab4x4
A/C suppliers
Aftermarket Air Conditioning products suppliers -
www.air-tique.com/ - Has both under dash and thru dash units and accesories.
www.hotrodair.com/ - Has both under dash and thru dash units and accesories.
www.vintageair.com/ - Has both under dash and thru dash units and accesories.
www.oldairproducts.com/ - over a dozen hang-on and under dash systems !
www.ackits.com/acsystems/universal.htm - several Universal Systems , look in left column
www.airpartsonline.com/default.tpl - Several hang-on universal kits.
www.rainbowproductsonline...=AC%20Kits
- Several hang-on and thru dash kits and parts
Ocean's
2015 - 2020 F150
Jun 2, 2016 12:14 AM
spacejesus
Ford Truck Parts for Sale
Sep 11, 2015 07:16 AM
desertwest
Dec 30, 2013 09:39 AM
winnipegf350
2009 - 2014 F150
34
Feb 15, 2012 06:47 PM
