Bumper straightening
Old Jun 6, 2004 | 08:05 AM
daveengelson's Avatar
daveengelson
Novice welder. Have a barton bumper want to install that needs straightening. Has a dent on one of the corners. Wonder if i can use oxy-acel to heat and remove dent using a mall. There is also section that needs to be welded, it is a filler piece that is connected to the bumper not as thick gauge metal as the bumper. I have Braz rod 3/32", and Gas god RG45 3/32. Any suggestions whether i can remove the dent using heat, and are any of the rods mentions appropriate for welding the small section
Any suggestions would be appreciated.
thank you,
dave
Old Jun 6, 2004 | 01:10 PM
Mike W's Avatar
Mike W
If you braze weld, it makes it hard to do any regular welding later. I am guessing that this is a typical rear bumper. A pic would be helpful for suggestions on getting the dent out.
Old Jun 6, 2004 | 02:28 PM
daveengelson
The truck was originally sold as fleet sale for gas and electric company and has what i would refer to as a utility type bumper. It has the embossed design in the steel and the towing section is about 1/2" gauge steel, but the section that i need to straighten is 1/4" gauge steel and about the size of a baseball. One of my concerns is that the repair is on the rounded corner and with heat and hammering if it would be incline to crack or split.
I will go ahead and try the RG45 3/32" rod on the section needing the welding and see how it comes out. It is a trim piece less than 1/8" steel and not sure really needs to be there. It fills gap between bottom of bed and top of bumper along the back.
Hope of some help.
thanx,
dave
jmadsen
Ford Truck Parts for Sale
Jun 3, 2017 07:10 PM
GB SISSON
50
Jun 16, 2014 05:59 AM
ZOOT
Oct 8, 2010 01:29 PM
tn.jed
Paint & Bodywork
Apr 25, 2010 05:40 PM
dragula
Paint & Bodywork
Dec 11, 2004 08:04 AM
