Some help after the new paint work.
Old Jun 6, 2004 | 04:20 AM
JLb300's Avatar
JLb300
I just finished spraying my 1971 F-100. I used acrylic with hardner. The overall paint looks good. The color is wimbelton white. Just one problem. Starting out I got too close on one area and got a run. After 3 days what is the best way to correct this run? What grit wet sand paper, and if it goes down to the primer can I just spot paint the area again or repaint the whole panel? The run is on the door panel. Thanks for all the help which made the job happen. Jim TN.
Old Jun 6, 2004 | 12:56 PM
Aekisu's Avatar
Aekisu
<cr>
Wetsand with some 600 until the run is nearly (not completely) flat with the top paint layer. Use care, remembering that the run is thinner at the top of the run. In some cases, the run may have even pulled paint from the top layer, making an indentation.
Then attack the area with some 1500 grit, smoothing the area and sanding out the 600 sanding marks.
Now wait a few warm days, allowing a complete cure. You want the area hard before you buff. This is especailly important since you have just exposed soft paint. After things have hardened up, buff out with your favorite buffing compound. If you don't have a buffer, you can do a small area it by hand.
If all else fails, you can repaint. Sand the area smooth with 400 grit, feather sanding into the good paint. Now sand the entire panel.
You have to build the repaired area, until it is the same height as the good paint. Spot the repaired area with paint. On your next pass, spray a larger area. Spray a larger area again. The idea is to keep stepping out so things blend in. Finish by spraying the entire panel.
Lots of work but in the end, noone will ever know.
Old Jun 6, 2004 | 03:52 PM
JLb300's Avatar
JLb300
Thanks Aekisu for the help. It sure helps to have access to experience people. Jim TN
