Tranny Kickdown Cable Adjustment
Old Jun 5, 2004 | 07:30 PM
nate_o23's Avatar
nate_o23
Hello all I am having some problems with the transmission in my 89 F150 with 5.0L and E4OD trans. I am hoping it is something simple like the kickdown cable being out of adjustment. I have looked but not been able to figure out how to adjust it. Please help. Thanks!!
Old Jun 7, 2004 | 12:46 PM
nate_o23's Avatar
nate_o23
Anybody???
Old Jun 7, 2004 | 01:22 PM
n578md's Avatar
n578md
I guess no one can help because there is no TV cable to adjust on an E4OD. It's all electronic. AOD 1993 and older have a Throttle Valve Cable though. Are you sure you have an E4OD?
Old Jun 8, 2004 | 02:10 PM
nate_o23's Avatar
nate_o23
OK Im a ******* its not an E4OD Its an AOD. It definitly has a throttle valve cable
Old Jun 8, 2004 | 03:59 PM
87-302-jim's Avatar
87-302-jim
I had the same problem you're describing on my '87 f150 c6 trans. I used a hose clamp mounted to the side of the trans. to take up excess play in the cable. It's been shifting fine now for 10yrs. and 70k. Look for an existing bolt close to the cable end, then drill a hole in a hose clamp to mount it. Run your cable thru the hose clamp, adjust the slack, then tighten the hose clamp. This should take care of any erratic shifting problems.
Grease & Gravel
19
Jan 19, 2025 11:27 AM
Mutilator712
Oct 12, 2016 06:08 PM
Building_Fords
Sep 5, 2016 09:24 PM
schoo
Apr 2, 2016 09:59 AM
F-250 restorer
Jan 12, 2013 01:47 PM
