Modular V10 (6.8l)
Braking shimmy
Old Jun 5, 2004 | 10:04 AM
Black beater's Avatar
Black beater
Braking shimmy
I have a 99 F250 that has a problem with a braking shimmy from a high speed to a complete stop. I have replaced the brakes all the way around and have had the rotors turned. I have heard about rotors losing their balance weight and having to be replaced. Has any else had this problem and found a good fix? Spending a couple of hundred dollars on rotors that don't fix the problem is not something I want to do.
Old Jun 5, 2004 | 04:00 PM
Monsta's Avatar
Monsta
Sit. Stay.
Never heard of rotor weights before...
Just for clarification...You say you replaced all the pads and resurfaced the rotors and the problem still exists?
I'd start looking at your front end suspension and steering components. (Ball joints is a good start)
Your front tires wearin' flat all the way across?
Old Jun 6, 2004 | 07:58 AM
Black beater
Yes all pads were replaced and the alignment is off a little, but I didn't think enough to make that much of a difference. The ball joints are still tight, but I plan on replacing them this fall. Tire wear is good.
Sixoh
1997 - 2003 F150
Oct 8, 2015 08:19 AM
Rusty_S
Sep 14, 2010 05:07 PM
04mountaineerguy
Apr 3, 2009 02:55 PM
dogg16
Bronco II
Aug 6, 2004 10:13 AM
Black Mack
Jul 24, 2003 09:11 AM
