Powershot wiring??
Old Jun 4, 2004 | 04:52 PM
bigdieseldav's Avatar
bigdieseldav
Powershot wiring??
This sounds like a dumb question, but after installing most of my Powershot kit, I installed the switches and for the life of me I cannot find a fuse that is on and off with the ignition, I tried several including the a/c fuse, ignition fuses and everyting else i could think of that would not work with the ignition off or in the accessory position. My switch still gets power. Anyone out there with on 02 that knows a fuse I can tap to solve the problem?? I'm in a pickle cause i refuse to run the propane without the correct wiring.... Thanks in advance....
Old Jun 4, 2004 | 04:58 PM
HeatStroked's Avatar
HeatStroked
There are 2-3 wires to tap into behind the fuse panel cover and under the steering column.
Take a multimeter and you'll find a few under there that are only hot with the ignition.
Old Jun 4, 2004 | 08:45 PM
bigdieseldav
hey thanks for the help heat, I will do that if I have to, but i would prefer a fuse tap source, you know any off the top of your head??
saauvenshine
Dec 3, 2014 04:31 PM
ckleine
Oct 9, 2014 01:27 PM
brentos
May 19, 2008 09:03 PM
rockcj
Oct 9, 2006 07:20 PM
Phydeaux88
Oct 15, 2004 07:28 AM
