inline radio fuses
Old Oct 7, 2014 | 06:46 AM
ckleine's Avatar
ckleine
inline radio fuses
I am installing an mp3/radio in my '82 f150 . what size fuses should I put inline at the constant power and ignition switch power wires ?
Old Oct 7, 2014 | 07:38 AM
Gary Lewis's Avatar
Gary Lewis
The owners manual should tell you that. It is a function of the radio and not the vehicle. And if you don't have the owners manual you should be able to find it on the internet.
Having said that, the constant-power "keep alive" circuit draws almost nothing so a 1 amp fuse will be more than adequate. But the switched-power fuse is more difficult to guess as it is a function of the power output of the unit. Many head units claim 20 watts/channel, and if yours is a 4-channel unit that would be a total of 80 watts. At 14 volts, which is the only place they'll kick out max power, you could conceivably draw more than 6 amps. But if you aren't going to run it at full tilt then a 5 amp fuse should be adequate. But if it blows when running it very loud go to then next size up.
Old Oct 7, 2014 | 08:26 AM
ckleine's Avatar
ckleine
I have a 3 amp in now . I was going to a 5 amp fuse to see how it goes . Thanks . The switched one is the one that blows .
Old Oct 7, 2014 | 07:59 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Constant power is just for memory. (milliamps)
How much wattage does your radio say it puts out?
It is easy to figure out the fuse you need.
Old Oct 9, 2014 | 12:54 PM
ckleine's Avatar
ckleine
52 x 4 . Ihave all 4 speakers hooked up .
Old Oct 9, 2014 | 12:59 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
So, very conservitvly you need 20A
60x4=240÷12=20.
Old Oct 9, 2014 | 01:27 PM
ckleine's Avatar
ckleine
Yea , I was thinking 15 to 20 amps . Thank you .
larriveeman
6.2L V8
Dec 21, 2011 07:42 PM
lilbilli0naire
Apr 9, 2008 12:01 PM
F150Texan
2004 - 2008 F150
Dec 2, 2006 12:03 AM
05f250fx4
20
Sep 11, 2005 11:45 AM
Keng
Jun 4, 2003 10:08 AM
