1978 - 1996 Big Bronco
Need your Help
Old Jun 3, 2004 | 10:57 PM
boltmann's Avatar
boltmann
Need your Help
Hey guys i am new to the site, hope you can help me out....I have a 91 bronco with the EFI 351w stroked to 408 cid, 9.5 compression, edelbrock 3782 cam (you can get specs from the edelbrock site http://www.edelbrock.com/automotive/index.html), edelbrock 3881 manifold, edelbrock twin 61mm throttle body, ford oem heads that have been ported exhaust only valves are 1.94 int and 160 exh., shorty headers and 3 inch exh...fuel pressure is good with stock injectors.
The motor pings pretty bad....does anybody know what lbs. per hr. the stock injectors are and should i go bigger....and how much bigger.....I did order custom chip from jet that doesnt change anything it runs the same with or without the chip so know i am going to try injectors....any help would be appreciated.
by the way I had a real bad experience with Jet and dont reccommend them has anybody else had a bad or good experience with them?
Old Jun 4, 2004 | 12:19 AM
Norm Carter's Avatar
Norm Carter
Are you running the stock distributor or aftermarket?
Old Jun 4, 2004 | 07:03 AM
fcarruth's Avatar
fcarruth
Almost sounds like your stock injectors are not supplying the fuel needed to keep the beast running smothly. Check out this link, it's pretty informative and you could call them and speak to a teck. I have heard they are very helpful. http://www.horsepowerfreaks.com/default.asp?Meta=FLEX
Good luck,
Old Jun 4, 2004 | 08:49 AM
boltmann's Avatar
boltmann
the distributor is stock
Old Jun 6, 2004 | 12:16 AM
bigric's Avatar
bigric
What do you have your base timing set to?
Old Jun 7, 2004 | 08:47 PM
boltmann's Avatar
boltmann
10 btdc know it is a 7 btdc to keep it from pinging so much....stills pings a litttle but driveable.
Old Jun 7, 2004 | 09:31 PM
JBronco's Avatar
JBronco
Simple question, but what's your fuel's octane rating?
Old Jun 9, 2004 | 11:06 PM
boltmann's Avatar
boltmann
the highest fuel we have here is 91 i did add octane booster but that does not help
Old Jun 10, 2004 | 10:18 AM
djjoshuad's Avatar
djjoshuad
the stock injectors on a 351 are 19#. the size you need depends on what power output your engine *should* have with your upgrades. Here is the formula for calculating injector size:
Injector # = est. horsepower x (BFSC/number of cylinders)
BFSC is the amount of fuel required to produce one horsepower. Use a BFSC of .45 for n/a applications, and .55 with a blower. so if you are not running a blower (and you have a v8), you multiply estimated horsepower by .05625; with a blower you multiply by .06875
If you plan on making 350HP with no blower, you will be fine with the stock 19# injectors: 350 x .05625 = 19.6875. if you plan on making more like 425HP, you will need to upgrade to 24#: 425 x .05625 = 23.9
for grins, here's what a 600HP blown motor would need: 600 x .06875 = 41.25 or 42# injectors. Keep in mind that it's better to have too large injectors than too small. Ford put 24# injectors in my '97 Cobra, but it only made an estimated 305HP stock.
Let me know if I can povide any more information
-Josh
Old Jun 12, 2004 | 12:11 AM
boltmann's Avatar
boltmann
thanks for the info...I am estimating between 300 and 350 hp...so my stock injectors should be fine, I will need to get another custom chip to open the injectors longer....
I am now having another problem.....I am going through distributor gears this is my third cam and 5th dist. gear this last time i went with an edelbrock cam instead of comp, new rebuilt dist. with new iron gear, lubed the crap out of it and it is still wearing out the gear...if im lucky i get 200 miles out of it....and less on a brass gear....my only guess now is that there is something wrong with the block that it is not letting the two mesh right....any suggestions or have you heard of this prob before?
Old Jun 12, 2004 | 01:42 PM
jsscart's Avatar
jsscart
Bad intake or something make it not sit right. Maybe cam bearings. Did you have new beraing installed? Is the cam gear wearing out too?
Old Jun 12, 2004 | 04:34 PM
boltmann's Avatar
boltmann
distributor does not go through the intake....everything is new....if i let it go long enough it does wear out the cam as well.
Old Jun 13, 2004 | 01:50 PM
Trublufords's Avatar
Trublufords
Roller cams use different dist drive gears than flat tappet cams, just a thought- Check Ford Motorsport Cat. for specs
51PanelMan
16
Apr 10, 2018 11:08 PM
verch101
Sep 21, 2013 09:49 AM
krautwolf
Jun 19, 2013 05:38 AM
kabcpapc
Sep 12, 2005 02:25 PM
remlle
Aug 3, 2005 05:45 PM
