Rough running 390 @ idle
Old Jun 5, 2004 | 05:53 PM
Fritolay's Avatar
Fritolay
is your dizzy gear worn? and have you had a chance to ppull the timing chain cover to inspect the chain??
Old Jun 5, 2004 | 10:27 PM
71Goose's Avatar
71Goose
Smile
Finally got to the bottom of it tonight. I thought I would re-check for vacuum leaks with propane this time instead of WD-40 and I found a vacumm leak where the intake manifold meets the riser plate for the carb. I tore everything down and I had the wrong gasket on it. Duh! After getting the right gasket ordered, I was disapointed to see that there is about a 1/8" gap that the gasket doesn't cover back where the pcv hose hooks up to the riser plate. So I bolted everything back up, the truck runs 100% better but there is still a small vac leak back there. Hmmmm. I thought about putting a small piece from the old gasket back there or trying to seal is with RVT silicone. Is it a bad idea to use silicone on that riser plate? Let me know, thanks
Old Mar 24, 2014 | 09:13 PM
70-360fe's Avatar
70-360fe
Been having similar issues. Read where some people have taken the heat riser off and use sand paper or file till flat. Can check by setting heat riser on a plane of glass to check for a flat plane on heat riser. Plan on trying this tomorrow, if you do go easy and check riser often till square.
jlo84truck
Nov 30, 2016 07:14 PM
Notmeofficer
Large Truck
Nov 29, 2016 01:10 PM
tbruz
Jun 8, 2016 03:09 PM
Monster Truck Ranch
Jan 6, 2016 07:12 PM
Fiddlemaker
Aug 25, 2015 09:05 PM
