Vin Information
Old Jun 3, 2004 | 09:19 PM
47coeman's Avatar
47coeman
Vin Information
Hello out there, anyone have any information on 41 Ford COE VIN #'s - no tgs on the body and I don't have the frame any help would be appreciated as to find someone that knows how to find information... TNX 47 coeman
Old Jun 4, 2004 | 09:55 AM
46fordtruck's Avatar
46fordtruck
First off, welcome to the Forums! No tags on body, and no frame, and no transmission, there are no more VIN numbers left on the truck. Ford put the VINs on the frame, transmission bellhousing, and a plate in the glove box door, that's all. So without these, then the truck no longer has a VIN number on it.
Old Jun 4, 2004 | 09:33 PM
47coeman's Avatar
47coeman
Vin Continuation
46 Ford Truck
You have satisfied some of my needs, do you know what a 41 COE vin would look like ??? and is it layed out like my 49 COE in which it tells the place of manufacture color and engine type although I know all of the COE's had V8's, any extra responce would be appreciated... TNX 47 COE Man
Old Jun 5, 2004 | 01:32 PM
46fordtruck
Pre '48 VIN's tells nothing about color, only way to tell that is to check in places for remaining paint. Plant where the truck was made is not told in early VIN's either, all you can tell is model, engine, and serial number. Some of the pre '48 COE's had 6 cylinders as an option, seen one that had one, and it was in the VIN that it should have a 6, but they are rare in the bigger trucks. Not sure if after '47 they became the only engine choice in COE's, but before '48 a 6 was optional.
Old Jun 5, 2004 | 04:01 PM
47coeman's Avatar
47coeman
The Vin Continues
46Ford Truck
I have been able to establish that 55K COE's were built between 1938-1947 not many as they were used for deliveries, shorter wheel base longer bed, makes sence. I still have not been able to establish how the vin # were layed out for the 55k that were built any places I can go to verify TNX
47coeman--------
Old Jun 5, 2004 | 04:46 PM
46fordtruck
Not sure how diff the VIN on a COE is, but this forum's moderator, 41Clay has a 1 ton '41, hopefully he will be by soon and can help on the VIN's for bigger '41 trucks. My specialty is the '42 -'47's, with some knowledge of pre '42's.
Old Jun 5, 2004 | 05:04 PM
47coeman's Avatar
47coeman
RE: Vin #
46Ford Truck
TNX, every bit helps I hope that someone out their has some knowledge of the COE's and can steer me in the right direction... 47coeman
Old Jun 5, 2004 | 09:29 PM
Carlene's Avatar
Carlene
Admom
Hey Skip - Welcome to FTE
I can't help you much on the COE's other than to point you to an older thread that may give you a little info.
https://www.ford-trucks.com/forums/s...d.php?t=141931
Also, I found the link to another COE guy that use to pop in here now & then. Check out Bill's site and you should be able to email him with your questions.
http://www.ozcoetrucks.web1000.com/
Tell Bill I sent you his way - he's a real nice guy.
Good luck and let us know what you find out.
Old Jun 5, 2004 | 10:46 PM
47coeman's Avatar
47coeman
TNX Carlene
Carlene TNX for the steer as I know Bill well I have two coe's on his web page and I will say hello> Keep your ears open for me as Bill can't help me either, as you know he is in Australia... Skip 47coeman
Old Jun 6, 2004 | 03:11 AM
mtflat's Avatar
mtflat
Hi Skip, I see you made it over here.
Here's a website that I've found helpful a time or two. Click on his Big Rigs link.
http://www.oldtrucks.com/
Old Jun 25, 2004 | 08:39 PM
47lady's Avatar
47lady
I am hoping you can help me. We have what we believe is a 1947 Ford Truck that has sat for years. We have been trying to find the VIN number. We found this on the frame rail above the steering box * 799Y206I455 *. The 799Y is hard to read but I am pretty sure that is what it is. We want to get a title as the truck has not been registered for years that we are aware of. Can anyone help confirm this is a correct VIN number for a 47 Ford truck?
Old Jun 26, 2004 | 01:10 AM
mtflat's Avatar
mtflat
Hi Lady,
That IS a vin for a 1947 one ton truck with a V8 engine. The very first number indicates the year in this case.
Old Jun 29, 2004 | 03:44 PM
47coeman's Avatar
47coeman
41 Vin
MT Flat
This is a vin of a 41 coe, it has a star in front as well as in back, can you make sence of it. I am still working on obtaining access to my research... TNX 47coeman
star99T279577star
Old Jun 30, 2004 | 12:01 AM
mtflat's Avatar
mtflat
That would be the vin.
That sounds like a normal vin for any '39-'42 Truck with a V8. The vins aren't very descriptive. What made it different by year was the serial number - low numbers = early series, high number = later series.
Old Jun 30, 2004 | 08:19 AM
47coeman's Avatar
47coeman
39-42 Vin
MTFLAT
TNX for the breakdown of the vin on the 41 is their a way to tell what the # of production is ? and what do the stars mean front and back. last question how do you find the information pertaining to the vins... TNX 47coeman
