Vin Information
Old Jun 30, 2004 | 09:58 AM
mtflat's Avatar
mtflat
I don't have a breakdown on production numbers. The website I took the engine number prefix from isn't working this morning, but 99C or 99T was a prefix Ford used starting in 1939 as a head (only) casting number and may have been used until '45 when the 59A/59AB heads were used.
"Generally" - The first 9 indicated production beginning in '39. Second 9 indicates V8. T indicates large truck (1 ton or larger). The stars on either end indicates this was the original ford serial number.
The trouble is, by modern vin standards these don't tell much and are inconsistent. For more info check out fordbarn.com or mac vanpelt's website
vanpeltsales.com/FH_web/flathead_home.htm
Someone there might have the production number breakdown for trucks.
Old Jul 2, 2004 | 08:00 PM
47lady's Avatar
47lady
Hi Tim
Thanks for the info in the VIN for the 47. Can you tell me if the I in the middle (* 799Y206 I 455 *) is actually and I (eye) or a 1 (one)? I thought I saw somewhere else on this site that it was a one. Just want to make sure before trying to get it registered.
Thanks again!
Old Jul 2, 2004 | 08:28 PM
mtflat's Avatar
mtflat
Yep, it's a 1 (one). Ford didn't use the letter "I" in the vin strings - they just skipped right from H to J.
Old Jul 2, 2004 | 08:40 PM
47lady's Avatar
47lady
Thanks for the help with the VIN. Now we can get it registered and start restoring it.
Old May 29, 2005 | 10:44 PM
WQ59B's Avatar
WQ59B
47coeman-- How the hell did you find out that approx 55K '38-47 COEs were built???? I need to learn this, being a compulsive number-cruncher & '40 COE owner. Hopefully you still read these forums........
Mark in NJ
40-09W
Old May 30, 2005 | 12:30 AM
vagabond1950's Avatar
vagabond1950
1947 Coe Vin#
Where exactly is the VIN# located on the frame?
Thanks
Old May 30, 2005 | 09:57 PM
WQ59B's Avatar
WQ59B
On my '40 COE it's on the top of the crossmember that's right in front of the engine, stamped in.
Old May 30, 2005 | 11:49 PM
47coeman's Avatar
47coeman
Registration of my 41
Hi Guys It has been along time, hope all is well and hope you have made progress on your projects as I have. I still need help on registration of my 41 COE any ideas out there as california is difficult. Please contact me for ideas TNX Skip-Landon 47coeman
Old May 31, 2005 | 12:24 AM
46fordtruck's Avatar
46fordtruck
Where are you running into probs Skip? Did you find a VIN number?
Old Jun 1, 2005 | 09:24 PM
WQ59B's Avatar
WQ59B
Skip- note my question to you 5 posts up....
Old Jun 2, 2005 | 08:22 PM
vagabond1950
47 Coe Vin#
Would the # be on the crossmember that the radiator sits on top of?
Old Jun 4, 2005 | 06:14 PM
WQ59B's Avatar
WQ59B
Yes: not the one the grille hooks to, nor the one that runs under the fan belt(s), but the one in between. Like I said- that's where mine is, tho it's hard to read. I could not get a legible pencil rubbing for the titling process (had to have a notarized statement instead).
Old Jun 7, 2005 | 12:08 PM
  #28
vagabond1950
COE VIN# Location
Thanks for the info, WQ95B, on the VIN# location. It was right where you said, but so faint you can barely see it.
Now I can finish this registration process that began in Dec!
Thanks again!!!!
jfields47
Large Truck
391
May 26, 2026 11:33 AM
Imperial Designs
Aug 29, 2024 09:31 AM
aggiect01
Aug 25, 2013 08:49 AM
44Jack
1947 and Older Ford Trucks
21
Aug 26, 2010 08:49 AM
oldjimmy
Mar 27, 2002 04:09 PM
