Offroad & 4x4
E4OD Overheats When Off-Roading
Old Jun 4, 2004 | 12:32 AM
Texan1983's Avatar
Texan1983
speaking of tranny coolers, i have always heard that you should run the biggest rated one you can fit/afford. is this true? i have been considering getting a b&m cooler for awhile but can't deside if i should get the 19,000lb or the 24,000lb gv. for my truck. i can fit both and there is only a $5 difference.
can you have too much cooling?
Old Jun 4, 2004 | 12:54 AM
fishmanndotcom's Avatar
fishmanndotcom
Originally Posted by 95-F-350-4x4
Hey cutts will a 2wd ZF tranny work or would it be better to find a 4wd one so it will have the adapter to run the transfer case? Or are the manual ones divorced?
i'm not really sure. i looked into it to put in mine but it was so expensive I decided to stick with my C6. when it goes i will be getting a Zf though! so i don't know the exact details. sorry man
only if there is such a thing as too much money can there be too much cooling
-cutts-
Old Jun 4, 2004 | 09:45 AM
95-F-350-4x4's Avatar
95-F-350-4x4
Originally Posted by fishmanndotcom
i'm not really sure. i looked into it to put in mine but it was so expensive I decided to stick with my C6. when it goes i will be getting a Zf though! so i don't know the exact details. sorry man-cutts-
No worries! I will just rebuild my E40D and put a good tranny cooler on it. Yeah it is expensive as hell to convert it to a manual and I think that project would be way over my head to complete.
Old Jun 4, 2004 | 10:12 AM
tite4x4's Avatar
tite4x4
Get the bigest cooler. It will only help. I've got a 24,000 one mounted on my rig.
Old Jun 4, 2004 | 11:11 AM
Texan1983's Avatar
Texan1983
ok thats what i thought, thanks
Old Jun 4, 2004 | 08:49 PM
bigredneck61088's Avatar
bigredneck61088
get an aftermarket cooler, maybe with a higher capacity
Old Jun 5, 2004 | 02:09 PM
Schmavic's Avatar
Schmavic
To All: Thanks for the advice,
To 94F140-408: Thanks for tip on the threads on the Autometer.
Re: the additional trans cooler(s). I've been reading that the E4OD is particularly sensititve to low pressure and the wrong cooler config will cause shift problems. This is supposed to be especially so when running a Banks Trans Command (which I have). Anyone have any comments?
Old Jun 5, 2004 | 11:52 PM
94F150-408's Avatar
94F150-408
I've often wondered about the huge tubes they run the fluild through in the standard tranny coolers and the possible drop in pressure. Most of the stacked plate design maintain a internal line size similar to that of your existing cooler lines, seems like this would be a preferred method just for that reason.
CollinsCD
Maryland Chapter
Aug 6, 2014 06:18 AM
SoCalAngler
Aug 5, 2014 08:33 AM
Schmavic
17
Jul 10, 2010 06:32 AM
JQ
Offroad & 4x4
Jul 11, 2007 06:36 PM
