Boost
Old Feb 15, 2001 | 01:21 PM
mcneal's Avatar
mcneal
Boost
What does "BOOST" mean? do? What part does it play with performance?
Old Feb 15, 2001 | 02:04 PM
D's Avatar
D
Boost
Boost is the amount of air pressure that a blower, (supercharger or turbocharger), supplies to the intake of an engine. Boost is normally measured in pounds per square inch. The more boost supplied to an engine, the more fuel that you can force into the engine, hence, the more horsepower you create. Boost can be controlled in several ways. We control and raise the boost on Powerstrokes with the aftermarket Performance Chips. This is how we increase the horsepower. More air+more fuel=more horsepower.
This pressure, boost, is proportional to engine rpm. Turbochargers use exhaust to spin a blower to create boost. Superchargers are belt driven. Turbochargers have what is called "turbo lag". This is the lag time, at idle, before the exhaust can spin the blower enough to create boost. Superchargers have very little if any lag, since they are belt driven.
Thanks
Danny
Old Feb 15, 2001 | 02:11 PM
alanscott's Avatar
alanscott
Boost
Boost refers to the rate of increased air forced into an engine over standard atmospheric pressure from an external compressor. The compressor could be in the form of a turbo or a belt/gear driven super charger. The engine burns fuel and air at a measured ratio, when you can force more air into the engine, you can then burn more fuel with that air, achieving higher power output.
alanscott
[link:ford-trucks.com/users/alanscott/|http://www.ford-trucks.net/users/alanscott/clubftesml.jpg]...Click!
Old Feb 15, 2001 | 06:50 PM
fredm's Avatar
fredm
Boost
Vinford
Dec 25, 2008 11:49 PM
rob92761
20
May 16, 2005 10:23 PM
Mustangfreak
Jun 27, 2004 12:52 PM
mcbryant
May 15, 2003 05:49 PM
