Turbo boost
Old May 11, 2005 | 09:54 PM
rob92761's Avatar
rob92761
Turbo boost
Does any one know what the max the trubo should boost before the wastegate opens
Old May 11, 2005 | 10:02 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The wastegate opens at 5 psi.
Old May 12, 2005 | 11:32 AM
johnny8's Avatar
johnny8
only if you have the wastegate actuator hooked up... yes..?
Old May 12, 2005 | 08:26 PM
cookie88's Avatar
cookie88
FTE Emeritus
Correct. With the actuator disconnected and no modifications made to the actuator rod, it will generally hold to ~24psi.
Old May 12, 2005 | 08:39 PM
444dieselrod's Avatar
444dieselrod
I thought the W/G started to open at 5* and was fully open at 15* when connected, and if it was disconected it would open slower ans still be open at 15* regardless because that was the way it was designed???
Diesel Rod
Old May 12, 2005 | 08:41 PM
johnny8's Avatar
johnny8
i thought the boost pressure had to overcome the spring that holds the wastegate closed b4 you would start to "loose boost"
Old May 12, 2005 | 08:47 PM
cookie88's Avatar
cookie88
FTE Emeritus
Wastegate STO is 5 psi, full open is not later than 8 psi. Spring pressure will generally hold to right around 24. 16 PSI is the STO pressure for the BB turbo.
Old May 12, 2005 | 09:11 PM
444dieselrod
intersting, even though I will never have to worry about my wastegate
thanks cookie.
Diesel Rod
Old May 12, 2005 | 10:53 PM
unluckylow's Avatar
unluckylow
I must have a serious problem cause when I unplug the red vacume line going to the waste gate there is no change and I cant hit 20 psi no matter what not even with my preditor tuner on the 85 hp setting. HUH I might have to look into this.
Old May 14, 2005 | 03:53 PM
cookie88's Avatar
cookie88
FTE Emeritus
Try putting more tension on the actuator rod.
Old May 14, 2005 | 05:11 PM
johnny8's Avatar
johnny8
(spoken in my best yoda immitation) yes... hehe... to obiwancookie you listen... get more power from your diesel you will... yes... you must believe in the force of the stroker... yeeeesssss.... the dark side... you have joined the dark side... yess... i feel the power of the stroker is very strong in you... lol...! sorry guys... all my buds are drivin' me crazy talking about the movie comin' out next weekend... i shouldn't have let it infect our forum... but hey i'm only human...!
Old May 14, 2005 | 08:23 PM
unluckylow's Avatar
unluckylow
So cookie does that mean to tighten the rod up correct.
Old May 14, 2005 | 09:59 PM
1984_355w's Avatar
1984_355w
What do they normally run for boost??
can you adjust this rod to change your boost numbers??
thanks
Old May 15, 2005 | 08:21 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yep, although it might be the Predator. Just for kicks I loaded the 100 horse Predator program on my truck today, and it barely made 24 psi. My truck will make low 30's easily with my chip. What kind of boost are you making with the stock programming?
The 99.5-03 will make around 17 psi stock. That can normally be tweaked up to the low 20's by disconnecting the actuator and/or increasing the seat pressure on the wastegate itself.
You must never underestimate the power of the dark side my young padewan.
Old May 15, 2005 | 08:27 PM
johnny8's Avatar
johnny8
"You must never underestimate the power of the dark side my young padewan."
and once you start down the path to the darkside, (aka, you start to do mods to your mule), forever will it dominate your destiny....!
