Bronco II Ford Bronco II
Clutch slipping
Old Jun 2, 2004 | 02:34 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Clutch slipping
I have a 86 BII with v-6.
Today at lunch the clutch pedal became very very stiff and…….then, the worst of situations.
Clutch slippage, …ug….is it the pressure plate…..or?. Could it be anything else that is easy to fix....
I tried to look under then darn thing and could not even see a throw out arm…
Any help
Old Jun 2, 2004 | 07:12 PM
IB Tim's Avatar
IB Tim
Hum.....thinking out loud.........could it just need a good bleeding
Hope someone has words of wisdom...
Old Jun 2, 2004 | 08:18 PM
Ken00's Avatar
Ken00
Sorry Tim, I'm not really into Manual trannies so I can't comment on what would make it stiff. You could give the Ranger forum a try since the BII is really the same truck and there's more traffic.
Old Jun 2, 2004 | 08:24 PM
IB Tim's Avatar
IB Tim
I did not know they were the same, are most BII's automatics.
What year is close to mine in the Ranger world?
This is so out of character for my truck, owned it since new.
Only 90k on it so, I believe it is low mileages.
Old Jun 2, 2004 | 08:41 PM
Ken00's Avatar
Ken00
Yep, they are sisters, almost the same each year.
Old Jun 2, 2004 | 08:43 PM
IB Tim's Avatar
IB Tim
Cool I will post over there.........also
Old Jun 2, 2004 | 11:54 PM
68 351 bronc's Avatar
68 351 bronc
I doubt the clutch needs bled as the line runs up to the resavor and thus air in the line runs up. I think it is just wishfull thinking that there is a simple fix. Probably time for a clutch.
If you havn't had any thing apart than it should never need bled.
If there was air in the line it would feel spongy, not stiff.
Old Jun 3, 2004 | 06:46 AM
IB Tim's Avatar
IB Tim
The problem is the clutch is only 15k old.
Old Jun 3, 2004 | 09:29 AM
mrshorty's Avatar
mrshorty
Did you replace the slave cylinder when you replaced the clutch? The reason you can't see a throw-out arm is because the slave cylinder is concentric (mounts around the input shaft rather than using a fork) and inside the bellhousing.
Assuming that the pressure plate and clutch disc are good, I'd be inclined to believe it's a hydraulic problem. Maybe not air in the line, but something else restricting fluid flow, or a bad slave cylinder or master cylinder. "Bleeding" the clutch might not resolve the issue, but it might be diagnostic. Does the fluid come out clean? Does the pedal move more freely with the bleeder valve open? If it were me, I'd probably start by bleeding the clutch (maybe flushing the clutch fluid would be a more appropriate term for what I would do), just because it's cheap and easy.
Old Jun 3, 2004 | 10:46 AM
IB Tim's Avatar
IB Tim
Well…. Here is an update; it finally stuck the pedal so it could not be depressed at all.
Found someone to pull the tranny...........got in it this morning to try and back it out.
Everything is fine pedal is as free as can be. Hum.......so I drove it to them and they are pulling the tranny.
It has got to be the salve........will keep all informed.
This realy bugs me…to have somethnig happen and then fine.
No wehn they did the clutch last time...........no salve was needed, so they said.
I think the proper thing to do, do the slave when it is apart.
Old Jun 3, 2004 | 04:57 PM
68 351 bronc
I don't like pulling transmissions. When Doing a clutch job I allways replace all parts no matter what the apearance.
Sorry to hear about your luck. The worst part is labor will be the biggest part of the bill.
I have an 89 Ranger I bought new. It still has the original clutch.
It's got 3.73 gears and I think that helps the life of the clutch a bit. 115,000 miles.
Ed
Old Jun 3, 2004 | 05:11 PM
IB Tim's Avatar
IB Tim
It seems I have one of a "weird" tranny some Oriental name.
Parts like the slave cylinder............... expensive.
Disk and Pressure plate not bad.
Pilot brg normal.
Old Jun 4, 2004 | 06:48 AM
IB Tim's Avatar
IB Tim
The name of my tranny TOY-KOYUO, as clsoe as I can get it.
I have been told it was only in for a coulpe of years, anyone know aobut these things.
Like good/bad any long term problems.
They have said it takes a special fluid that you cannot find any more!
Old Jun 4, 2004 | 07:58 AM
GrayRanger4x4's Avatar
GrayRanger4x4
Question
I dont know for sure but I think youe Tranny is a FM 146.Look at the bottom of the tranny if it has a flat stamped steel plat with a dran plug in the middle of it, it is a FM146.That s what most 88-90 BII have in them.I would get a new clutch set about $125.00 and put it in and have the flywheel turned then you know its right.The pilot barring goes in the flywheel on a 2,9 engin{Fords better idea}As far as the hyd unless you ran it dry or broke something it should be fine,check everything for leaks. JMO
Old Jun 4, 2004 | 10:07 AM
mrshorty's Avatar
mrshorty
Haven't heard a lot bad said about the Toyo-Kogyo, haven't heard a lot of good said about it either. I suspect that, like the Mitsubishi transmissions (FM-145 and 146), it's adequate for the job it's been asked to do.
According to the information I have, the TK transmission uses regular old Mercon ATF as a lubricant. I'm not sure who's telling you that fluid isn't available for it anymore, but Mercon is easily obtained just about anywhere.
