1978 - 1996 Big Bronco
rebuilt smoking engine!!
Old Jun 1, 2004 | 09:29 PM
Fordbronco69's Avatar
Fordbronco69
Infidel
I had my engine rebuilt about 5 months ago and everytime i slame on the gas to pass someone or just show off theres a smoke trail. Ive got a Edelbrock 650 CFM carb 4 bbl and a 400m. Was wondering if it this smoke had anything to do with bad timing, coil, plugs, or wires?
Old Jun 1, 2004 | 09:37 PM
DW2455's Avatar
DW2455
whats it look like? black smoke ? white? DW
Old Jun 1, 2004 | 09:38 PM
Fordbronco69
Infidel
black smoke
Old Jun 1, 2004 | 09:42 PM
DW2455's Avatar
DW2455
black smoke would sugest to me GAS, a rich condition, could be weak ignition system, bad or wrong heat range plugs, improperly jetted or malfunctioning carb. hope this helps DW
Old Jun 1, 2004 | 10:46 PM
Fordbronco69
Infidel
it has the stock ignition system should i maybe upgrade to an updated one? or just buy new coil, plug wires...ect. What brands does anyone prefure?
Old Jun 2, 2004 | 09:49 AM
djjoshuad's Avatar
djjoshuad
I'd say better plugs and a better coil would be a cheap and easy place to start. It sounds like you're not getting enough spark at WOT to burn off all the gas that your carb is spraying in. do you notice this every time you open up the secondaries? If so, get a new coil, and if you're running stock plugs/wires, you will probably want to upgrade those as well. Keep in mind that your stock setup was for a 2-bbl carb, so it never needed enough spark to burn 4-bbl worth of gas
-Josh
Old Jun 2, 2004 | 10:08 AM
Fordbronco69
Infidel
going to autozone in a few mins to get a accel super stock coil. will that coil be enough? i think its around 40,000 volts
Old Jun 2, 2004 | 10:09 AM
djjoshuad's Avatar
djjoshuad
heh yeah that should do it... but be sure that you have good 9mm wires to handle all that spark. might as well upgrade to the accel dist. cap and rotor too. IIRC, they're not too expensive and they are built for high spark.
-Josh
Old Jun 2, 2004 | 10:16 AM
Fordbronco69
Infidel
aight...gonna get new wires to...number 6 kinda melted after hitting the headers a few months back and it's been "repaired" ^.^
Old Jun 2, 2004 | 10:29 AM
djjoshuad's Avatar
djjoshuad
hell, that could be a big part of the problem right there... are you noticing any misfire at WOT? If so, there's your black smoke. anyway, if that is your problem, then the new wires and coil will fix you right up :-)
-Josh
Old Jun 10, 2004 | 09:56 AM
djjoshuad's Avatar
djjoshuad
hey, any update? did the new stuff fix your problem?
-Josh
Old Jun 10, 2004 | 03:12 PM
Fordbronco69
Infidel
oh yay fergot to update...as soon as i put the new stuff on all the problems went away
Old Jun 10, 2004 | 03:17 PM
djjoshuad's Avatar
djjoshuad
ahhh gotta love the ol' tune-up trick
