Biggest tire size without leveling kit
give it a day or so before you start experimenting, you might get lucky and someone will reply.... I talked to a dealer and they dont even know their name let alone what size tire will fit. I also tried going to two different tire places.....different answers, I even went to an offroad place and they were not "quite sure"....so good luck to you!
Originally Posted by EZLariat
I wanted to put 305/55/20 nitto terra grapplers on my 2004 4X4 lariat. I did not want to put the leveling kit on the front on my truck. Does anyone know if this would work without rubbing?
It was catching the inside of the flare where they attach to the fender.
The difference could have been just a matter of the wheel back space.
But thats just a guess, cuz I'm not sure what the measurements are...
it appeared that his back space was more than mine...as in the lug nuts
we more flush with the outside of the wheel than mine...therefore having more tire
inside of the wheel well.
williamson-
sorry i haven't yet put any pics up in my gallery....been meaning to do that. i'm still pondering lifting the front end to level things out. as for lowering the rear end...if you want to, go for it! it's your truck!
the only issues, well asthetically speaking, i see with leveling the truck...front or rear....are what's going to happen when you're towing or hauling a heavy load. if it's level without a trailer/load....will it sit nose up with a trailer hooked up or a load in the bed? i suppose you could always level it out and beef the rear suspension up a bit so there is no sagging under weight.....
Originally Posted by patuca
williamson-
