Drive by/Die by wire?
Old May 26, 2004 | 11:04 PM
jimmyj's Avatar
jimmyj
After 8,000 perfect miles my 04 F150 5.4L XLT has stalled 4 times (three this evening.) The first two times were while driving about 20-25 mph and the last two were after coming to a stop sign.
The engine rpm's dropped to 400-500 and then it died. I felt no vibration and did not hear anything.
The last time it stalled this evening it took two tries to restart the engine. After it started it idled just over 1,000 rpm for the last three blocks home. I assume that this was normal after the engine did not start with two cranks.
I have always used Shell gas until just recently. I have changed to Murphy (Wal-mart) which I am told is Coastal gas. The price difference of $0.06/gal. has suddenly become important. I had just filled up before the last three stalls, today.
Funny things can happen when gas gets too high or hard to get. Matter of fact I plan to get a locking gas cap later this week.
Any thoughts or similar experience?
Old May 26, 2004 | 11:09 PM
subliminaldanger's Avatar
subliminaldanger
only thing i can think of is impurities in the gas or a real old gas. Best bet is to switch to a different gas and see if the problem continues. Whats a $1.50 saved every fill up when you have to pay a couple thousand for a new engine cause you were using cheapo gas.
Old May 26, 2004 | 11:17 PM
ieee_raider's Avatar
ieee_raider
Suggestion:
Take it in for service.
Old May 27, 2004 | 02:49 AM
Toreador's Avatar
Toreador
I agree with Ieee. You better take it in for a checkup. Gas is not causing this problem.
Old Jun 2, 2004 | 01:13 PM
jimmyj's Avatar
jimmyj
Thanks for the replies. Sorry for the delayed follow-up, been on vacation. I took your advice and called my dealer.
He said if there was bad gas in town they would have heard about it, and they had not heard anything.
The Service Manager, Marc, told me he had not heard of any issues like I was describing. It may have been needing some time to adjust to a really different ignition point.
Then he asked, "Is it happening now?"
"No."
"Well, if it happens again, bring it in. Otherwise, just keep drivin' and let us know the next time you change gas."
End of conversation.
I have almost used this tank up. When I fill up again, I'm going back across the street to Shell, where I never had a problem. Not going to worry about an extra $1.00 per fill-up. Diagnostics costs $40 and that's more than the number of full-ups that I do in a year. If one of the computers is a little slow, I am sure I'll get it caught before the warranty expires.
Thanks, again, for the advice.
jimmyj
04 F150 SCab XLT 5.4L in Dark Shadow Gray
Old Jun 2, 2004 | 10:39 PM
Threadhead's Avatar
Threadhead
This is a very common misconception, that there is difference in gas from one brand to another. Well, there is, but the difference is only in the additives. And then again, most of the additives between brands are nearly identical.
So, the gas you are getting at Wal-Mart vs. Shell comes out of the same pipe at the distribution hub. Ok, there is a chance the trucks come from differnt hubs, but those hubs almost certainly are fed from the same refinery. It's 99.8% the same. That's why the dealer would know if there was a 'bad batch' of gas... it would affect every station in an area. Even this is extremely remote.
I used to do gasoline analysis for Tosco, Giant, Phillips, etc.
Josrobinson
20
Jun 22, 2014 07:40 AM
tlk401
1983 - 2012 Ranger & B-Series
16
Apr 20, 2013 12:50 AM
Steve_250
Apr 17, 2010 07:52 AM
NeoCowboy
16
Mar 26, 2010 02:56 PM
freeway
1978 - 1996 Big Bronco
Jan 23, 2001 08:48 AM
