Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Removing rust with voltage plus acid
Old May 31, 2004 | 10:30 PM
Mike W's Avatar
Mike W
I did a pulley today using about a cup of aluminum wheel brightener in 2 gal of water. The current was 3 amps at about 10 volts. I ran it for 3 hours. The pulley was on the positive lead which is reversed from the washing soda setup.
The water turned a dark green. Is there a chemist in the house? The pulley was not completely rusted but had some thick rust in one of the groves.
Before and after pics: Edit- Bad link -Admin
Old May 31, 2004 | 10:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
An old trick is to use aluminum foil and vinegar to remove rust from chrome. No battery needed.
Old Jun 1, 2004 | 11:42 AM
TJC1989's Avatar
TJC1989
Before and after pics: http://img36.photobucket.com/albums...ic=DSC00290.jpg
Mike your pictures are not working. Please explain the voltage hookup.
Old Jun 1, 2004 | 12:12 PM
Mike W's Avatar
Mike W
I fixed the pic I think. The positive lead goes to the pulley. The negative to a stainless tube.
http://img36.photobucket.com/albums/...t=DSC00307.jpg
Old Jun 1, 2004 | 04:53 PM
ZRX61's Avatar
ZRX61
I just use a 20% Muratic Acid/80% Water mix. It takes off rust & Cad/Nickel/Zinc plate in about 5-15 seconds...
Old Jun 1, 2004 | 08:25 PM
Kenny's Avatar
Kenny
Mike,
I'm not a chemist (by any means), but I think the green color has something to do with the iron displacing the hydrogen in the acid.
Old Jun 2, 2004 | 12:42 PM
beartracks's Avatar
beartracks
I've had a little experience with sacrificial anodes and plating. I suspect you are plating the stainless onto the part and the rust is going away in the process. But hey! I'm no expert or I wouldn't ask all those questions on this site.
Old Jun 3, 2004 | 03:04 PM
dfisher1's Avatar
dfisher1
All,
There are some questions that need answering before we can explain these starnge going ons.
Since when did aluminum rust orange? This pulley is aluminum, isn't it? My guess is, that the surface discoloration was a stain not a corrosive coating?, Maybe?
Copper oxide will give off a green color when dissolved in an acidiic solution (i.e. sulfuric acid). Generally, when performing an anodic sacrifical process the sacrifical element is not the part interest. This means that aluminum should be less corrosive than stainless steel. I assure you, that is not the case in my world, I think? So, the electrons are driven to the aluminum via electrcical potential, but the cathode is more stable than the anode. Technically, this should not have worked? Did anyone notice the texture on the outside of the pulley's V-grooves? Was that texture present previous to the process? I'll bet, not? I'm getting lost in my own analysis.
I need an objective opinion on the sacrifical level of aluminum vs. SST? Aluminum should be the cathode, right?
Help me out,
KingFisher
Old Jun 3, 2004 | 09:47 PM
beartracks's Avatar
beartracks
I'll bite
Alrighty then, I say we discuss it. I think I've learned more from arguing a point and hearing the replys than I did in high school.
I'm thinkin the pulley is steel.
A sacrificial anode system protects something from corosion. Zinc might be "sacrificed" to protect a steel tank. My question would be, where does the zinc go? Does it absorb the corrosion or does it plate onto the steel?
Plating might be a little bit different.
Where's my beer?
Old Jun 4, 2004 | 08:06 PM
Kenny's Avatar
Kenny
I was thinking the pulley was steel also.
I work as a plater in a Hard Chrome plating shop. When we plate, The part itself is grounded (negative), and the annodes are hooked to positive. Before we start plating though, we always reverse the current to clean the parts first. Our sacrificial annodes (we call them drop annodes) are in place in the tank to attract the removed particles away from the parts.
Without seeing exactly how Mike actually had it all set up, it sounds like he did pretty much the same things as we do (except our removed particles are released into the Chromic acid bath). Our parts are all de-greased before we start, and look really clean to the naked eye before we begin, so we only run in reverse (Positive to part) for a very short time.
Sometimes we strip the parts first to remove existing chrome. We use a Hydrochloric acid/hot water mixture for this. The mix is as clear as water, but always turns green.
Old Jun 5, 2004 | 12:55 PM
Mike W's Avatar
Mike W
The pulley was steel. I need to get some more acid. The wheel brightener mentioned hydrofloric and one other in it. You can use washing soda instead but the acid is a lot faster.
Old Jun 6, 2004 | 03:10 AM
faroffthetrack's Avatar
faroffthetrack
Wow I think I'm taking in about 2% of what you guys are saying but it sure is interesting.
That bed sure dose look mighty nice...
Old Jun 19, 2004 | 08:45 PM
jniolon's Avatar
jniolon
old and in the way
rust removal
do a google on electrolytic rust removal... there are volumes and dozens of web pages showing the process... it's not very complicated... but some of the processes are very ingenious..
john
Old Jul 18, 2004 | 11:43 PM
meangenejr's Avatar
meangenejr
Thumbs up Rust removal
I use this method of rust removal every day in my car port. Fill a container full enough to cover your article and add 1 tablespoon of baking powder per gallon of water used. Hook negative of battery charger to item to derust and the positive to a piece of metal (ferrous) Don't use aluminum. submerge both items. arrange the items in relation to each other until your charger reads about 4 amps. Leave for about 3 hours and you should be able to brush the rust off with very little effort.
Gene
Old Jul 18, 2004 | 11:49 PM
tkondro's Avatar
tkondro
I was watching myth busters and for surface rust, coca cola and tin foil (aluminum foil) works also. And think about it we drink that stuff!!
