Burning Antifreeze?
Old May 31, 2004 | 08:34 PM
braineless's Avatar
braineless
Burning Antifreeze?
My '86 Ranger is putting out a sweet smell out of the exhaust... thought it might be antifreeze leaking... would that mean a cracked head? I know that
is a problem for the 2.9 V6 (what mine is) Thanks in advance for any help...
Jeremy
Old May 31, 2004 | 11:06 PM
marvoles's Avatar
marvoles
It could be your head, or it might be your heater core leaking down or your exhaust,
Old Jun 1, 2004 | 09:36 AM
shaggymane's Avatar
shaggymane
a bad head gasket would do that too
Old Jun 1, 2004 | 10:56 AM
'04 4.0 XLT's Avatar
'04 4.0 XLT
Other thoughts: Cracked block (bites tongue), intake manifold or gasket. Have you noticed any white smoke coming from the exhaust? How do your plugs look? Are they wet? How does your oil look? If the oil looks like a chocolate milkshake you have definite problems. Quit driving it immediately!
Post back with your findings.
Old Jun 1, 2004 | 08:06 PM
Ken00's Avatar
Ken00
That sounds like coolant, I would suspect intake manifold leak or cracked head, the cylinder(s) that are burning coolant will have steam cleaned plugs. You can also try a compression test and cooling system pressure test. Cylinder # 1 & 6 are the ones that normally have the cracks.
Old Jun 2, 2004 | 08:56 AM
braineless's Avatar
braineless
Yep... lots of smoke... dont have my license yet... so I dont have to worry about driving it. I have a parts truck with the same engine. would it be cheaper to just replace the engine? I dont want to put any more money into it than I absolutely hafta. Thanks Jeremy.
Old Jun 2, 2004 | 09:39 AM
Ken00's Avatar
Ken00
IF the oil is clear of coolant then you could pull the heads from the other engine, have them magnafluxed and put them on your current engine if they test OK.
Old Jun 3, 2004 | 11:40 AM
braineless's Avatar
braineless
Would I be able to see coolant in the oil by checking the oil level or by changing the oil?
Old Jun 3, 2004 | 08:01 PM
Ken00's Avatar
Ken00
The oil would look a bit like chocolate milk, also moisture under the oil cap.
viper29
Oct 9, 2015 03:16 PM
Ftwofitty
Feb 18, 2011 10:29 AM
tehwarrior
1997 - 2003 F150
Oct 9, 2009 04:47 PM
attakus
Aerostar
21
Mar 13, 2006 02:59 AM
stateteam
1997 - 2003 F150
Jun 29, 2004 09:12 AM
