dazed and confused
Old 03-09-2001, 03:57 PM
logan_85's Avatar
logan_85
logan_85 is offline
dazed and confused
Old 03-17-2001, 12:42 AM
junkyardkid's Avatar
junkyardkid
junkyardkid is offline
dazed and confused
why would my oil become thick and gray after an injector change? i changed the oil yesterday, ran the truck 30 min. ran strong, sounded good, no smoke. checked the oil, it was thin and gray. what gives?
Old 03-17-2001, 03:26 AM
The Diesel Dude's Avatar
The Diesel Dude
The Diesel Dude is offline
dazed and confused
Sounds like coolant in the oil to me. Why did the injectors need to be changed?
Old 03-17-2001, 10:11 AM
junkyardkid
dazed and confused
i took them and had them banged, only 5 worked. so i had all new ones put in. this is driving me crazy! thanks for your help
Old 03-17-2001, 10:25 AM
junkyardkid
dazed and confused
how do i remove the coolant from the oil, how do i avoid this problem, and (the big one) what caused this problem? thanks again
Old 03-17-2001, 05:05 PM
The Diesel Dude
dazed and confused
I'm not sure if we are talking about a Power Stroke or an IDI diesel. Was the oil this way before you changed the injectors? I am going to assume that it is an IDI engine. It sounds to me like you've got quite a lot of coolant in the oil in which case it is likely the fault of a defective oil cooler. Unless the head gasket failed at a location where the coolant would leak directly to the cylinder head oil return hole, it is not likely there would be enough coolant in the oil to change the overall composition of the oil,in my opinion. Run a pressuer leak-down test on the cooling system to see if you can find the source of the leakage. Are you loosing coolant from the radiator?
Old 03-17-2001, 11:35 PM
junkyardkid
dazed and confused
i have a 6.9 i lost coolant just after the injector swap, then it leveled out. i will do a pressure test monday, thanks
Old 03-18-2001, 02:09 AM
The Diesel Dude
dazed and confused
I can't think of any reason the changing of the injectors would cause the coolant to leak into the oil (I am assuming you didn't take the intake manifold off). There is no coolant in the intake manifold but the gasket blocks off 4 casting holes on each bank that go to the waterjacket in the heads. Let us know what you fimd.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: dazed and confused
