Sensor Locations
Also, i suspect that my cat may be clogged. What is the procedure for checking its performance. Ive read references to the temperature method, but didnt get any details.
I want to check the usual suspects, TPS, IAC, 02 sensor, fuel pressure regulator, fuel filter. My Chiltons manual is almost worthless because it covers 1966-1986. I have a Fuel Injected 86.
Does anyone know where i can look at a diagram of the 302, or tell me exactly where each part is.
Sorry for asking so much, thanks in advance.
Ruke
Running rich: I'd check fuel preasure first. If it's high replace the fuel preasure regulator. Also, if your fuel return line gets pinched or damaged, it can cause preasure to skyrocket.
Also check computer codes. Check spark plugs/tuneup.
Since I'm bored, and in a good mood
Checking cat: no idea.
TPS: on bottom of throttle body
IAC: side of throttle body
O2 sensor: on passenger side exhaust manifold, toward the firewall.
Fuel preasure regulator: on fuel rail, attached to lower intake manifold, near the fire wall. Test port is on same side, towards the front.
Fuel filter: You have two. Both on drivers side. Easy one is just below the firewall on the frame rail, near the high preasure fuel pump (you also have a low preasure pump in the gas tank). The other filter is hidden behind a heat shield next to the transfer case, on the frame rail.
Ruke
if it is the fuel pressure reg. it very well may have killed your cat from running too rich. i just had the reg. die on my explorer, and it completely clogged the front end of the first cat.
