Temperature sensor location
Old Aug 7, 2003 | 08:28 PM
1986owner's Avatar
1986owner
Question Temperature sensor location
Recently inherited a 1986 F150 with a 302. The cooling system had not been maintained very well. The temp gauge is not working (it does not move at all). I suspect the sensor. Can anyone tell me where it is located and the best way to check whether it is the sensor or gauge.
Old Aug 11, 2003 | 10:46 PM
steve83's Avatar
steve83
Top of the engine L front. It has a single R/Wh wire. Put the key in the RUN position, ground the terminal for a few seconds, and see where the needle is. If it's near H or coming down from there, it's the sender. If not, it's the gauge or the circuit between them.
bh70116
1978 - 1996 Big Bronco
Aug 29, 2010 06:32 PM
1986F350witha7.3
Jun 15, 2010 12:52 PM
mrider1
Dec 22, 2005 09:43 AM
general--lee
Apr 5, 2004 02:13 PM
