Correcting speedo
Old May 30, 2004 | 05:09 PM
Trublufords's Avatar
Trublufords
Correcting speedo
Anybody use a computer control pulse device to correct speedo like Abbott ind. ERA (electronic ratio adapter) or Superlift's device?? I know all about my programable speedo and its 6 times I can do it .I am putting it on 93 Bronco -39.5 tires speed sensor on rear differential. THANKS FOR ANY-ANY RESPONSE!!!!!
Old May 30, 2004 | 05:55 PM
Blue Rage's Avatar
Blue Rage
The Superlift Truspeed should come with complete instructions that tell you how to program and calibrate everything. Here in a few weeks, I can tell you how hard it is.
Old May 30, 2004 | 09:25 PM
Trublufords
The only problem I am running into is mounting the box (1in. thickx4in. longx3in. wide) 6inches from speed sensor on rear axle,it is not a sealed unit - you have to adjust dip settings-10 of them,and 4 dip settings for 2 or 3 wire speed sensor. Must unscrew cover to access them.
Old May 30, 2004 | 09:27 PM
Trublufords
PS I have complete instructions and toll free phone # , called and was told harder to use on 92-96 F150-Bronco!!
Old May 31, 2004 | 09:33 PM
lindsay's Avatar
lindsay
auto meter makes 2 electronic speed sensors that you can adjust. they hook into your tranny like a mustang do. you should have the hole in your tranny for it.
Old Jun 1, 2004 | 01:59 AM
94F150-408's Avatar
94F150-408
On the Superlift module, I was able to mount it under the dash board. They have you splice into the wiring behind the speedometer instead of a t the speed sensor in the diff. I have some pics of it in my gallery I believe. It wasent too bad and easy to adjust for different tire sizes. What brand are you installing that it has to be outside?
Van Abbott
Jan 3, 2005 05:59 PM
Abbott
3.0L V6
Mar 21, 2004 09:22 PM
alanscott
Dec 31, 2003 04:33 PM
