no spark!!!
Old May 30, 2004 | 01:38 PM
tup's Avatar
tup
Question no spark!!!
Help please, I have a 1976 f-250, 390 4bbl engine just rebuilt started fine ran great. bushing in distributor went bad. new dist. and it started fine. before I got a chance to set the timing I couldn't get it to fire changed plugs in fear or fouled. still nothing. had ignition mod tested it was bad, why suddenly bad I don't know any way I replaced it and still no spark . Help Me Please
TUp
Old May 30, 2004 | 03:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
Did you get the distributor in right?
Old May 30, 2004 | 05:35 PM
tup's Avatar
tup
Question
Thanks for reply, I dropped it in the manifold made sure it engaged the oil pump shaft and the rotor was lined up where i marked it what else could I have screwed up?
help tup
Old May 30, 2004 | 07:40 PM
LxMan1's Avatar
LxMan1
Possibly a bad pick-up coil in the new dizzy?
Old May 30, 2004 | 07:57 PM
tup's Avatar
tup
what do you think are the odds of the pick-up being bad in a new distributor?
does any one know a good method to test a coil?
thanks tup
Old May 30, 2004 | 10:02 PM
Boosted 65's Avatar
Boosted 65
Hello Tup! I had the same freakin' problem this week. I checked everything, distributor, ignition, coil. Then I took of the cap to see if the rotor was turning. It wasn't! The distributor gear was fine, the cam gear was fine, so guess what? It must be a broken timing chain. I'm in the process of fixing it now. What a pain. Make sure your rotor is advancing before you check anything else. Best of luck to ya. Tom
Old May 30, 2004 | 10:46 PM
wezol5484's Avatar
wezol5484
I dunno if there is a way to test the coil other than just getting a new one. There not that expensive, I just had to replace mine last week and it was $23. Other than that I would have go with LXman on the pick-up. It may be a new dizzy but you never know. Pick-ups arent expensive either.
Old May 30, 2004 | 11:26 PM
tup's Avatar
tup
thanks for the info I have checked to see if the rotor is turnning and it was but at this point I will check again, and also try and get into the whole pick-up can of worms.
thanks
tup
Old May 30, 2004 | 11:40 PM
wezol5484's Avatar
wezol5484
Yea it couldnt hurt. My Pick-up was $15. Ive had to replace all of my ignition sometime or another lol.
Old May 31, 2004 | 01:32 PM
tup's Avatar
tup
Okay fellas I have replaced the pick-up, ignition switch, coil, dizzy, ignition mod and still nothing. I am out of $$$ and very low on sanity. I cant help but think it is something simple, but what? all wiring to dizzy, and coil and modual have continuity. I am lost.
tup
Old May 31, 2004 | 02:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
There is a whole diagnostic procedure in repair manuals that takes you step by step thru checking out your ignition system.
Eastwinn
Jan 9, 2014 08:38 AM
1 Excursion camper
Modular V10 (6.8l)
26
Nov 14, 2012 08:21 PM
Sandidande
18
May 15, 2007 10:10 PM
