Ranger auto trans problem
Old May 29, 2004 | 04:15 PM
freebob's Avatar
freebob
Cool Ranger auto trans problem
I have a 2000 ranger 3L Auto (OD). 35,000 easy miles. Sudden failure; speedometer and odometer stopped working, OD light flashes, ck engine light on, ABS light on. When first driven after shutting off , First shift from low at around 45 MPH, freewheels if gas released, then shifts erratically, violently and "hunts". Speedo started to work again for about 1 mile, then quit again. Any suggestions???
Old May 29, 2004 | 04:38 PM
Bob Ayers's Avatar
Bob Ayers
A common problem, the RABS speed sensor in the rear DIFF. is bad. Look for an electrical connection in the top of the rear DIFF., and it's held in with 1 bolt.
Old May 29, 2004 | 04:49 PM
freebob's Avatar
freebob
Thanks, I will look for it. Is it a Ford only part, or aftermarket like NAPA?
Old May 29, 2004 | 05:06 PM
Bob Ayers's Avatar
Bob Ayers
When I replaced mine, I got it from Ford, for about $20. I'm not sure if NAPA, or any other auto parts store would have it.
Old Jun 2, 2004 | 04:55 PM
freebob's Avatar
freebob
Bob
Thanks for the help. replaced speed sensor... works great! Life should be so simple!
Old Jun 3, 2004 | 05:50 AM
sorensenj's Avatar
sorensenj
Thanks to some advice I got on this forum I was able to find the needed speed sensor on a web site. http://www.advanceautoparts.com/ was the name of the site. There are two others (http://http://www.rockauto.com/ and www.teamautoparts.com/ ) but they were out of the part at the time.
weldboy
Oct 26, 2011 07:37 PM
stonewal32
Jun 4, 2011 07:13 PM
landcruzr
Dec 24, 2009 08:59 PM
CrimsonRanger
Jul 6, 2008 10:35 PM
Ugly Since Birth
May 24, 2005 08:00 PM
