what kind of hose to use for rad overflow?
05-29-2004, 03:41 PM
on
What properties does a hose have to have in order to be rad fluid safe?
I'd like to use clear hose. Automotive places around here don't really carry clear stuff, but I can get it from work.
05-29-2004, 05:19 PM
The overflow hose doesn't have to have any particular properties. There isn't any high pressures on it.
05-29-2004, 06:39 PM
on
Well the guy at Piston Ring said it has to be suited for Rad fluid or it will just eat away at it. Is this guy bluffing me
05-29-2004, 07:57 PM
on
Try the clear - if it discolors, switch to something else.
05-29-2004, 08:22 PM
You won't be out much if it's the wrong hose. Most use a vacuum hose or a fuel hose.
05-29-2004, 10:05 PM
on
Quote:
I got tons at work, so I'll just keep replacing it if it does.
06-01-2004, 07:49 PM
on
If it discolors, it's probably reacting to the antifreeze and being dissolved - that's why I suggested going to something else if this happens. Medical-grade clear tubing is good stuff but it's expensive.
Cameo 57
04-29-2014 03:35 PM
WhiteBeast-05-powers
09-20-2011 10:44 AM
One79one71
13
05-18-2011 12:13 PM
47 Mercury Firetruck
1947 and Older Ford Trucks
01-13-2011 08:05 PM
