Aerostar Ford Aerostar
Problems After Long Haul
Old May 29, 2004 | 04:43 AM
razor_jim's Avatar
razor_jim
I just got back from a long (140+ mile) trip on the freeway, and I noticed on the way back home on normal streets that my van is starting to have a hard time taking off. It'll go when I press the gas, but very slowly, and the engine just won't power up like it usually does. However, the problem comes and goes when I stop at stop signs and then take off. I don't think it's a transmission problem, just doesn't seem like it. It seems more like the engine is having the issue. Does anyone know what might be wrong? Could the thing just be hot or something?
I drive an '89 3.0L 2WD.
Old May 29, 2004 | 03:51 PM
shel 67's Avatar
shel 67
The problem could be that your cat converter is plugged up. If you are having to use a lot of pedal to move it could be the cat.
Old May 30, 2004 | 04:11 AM
razor_jim's Avatar
razor_jim
Well I drove it today and there wasn't a single problem. The engine was probably tired after taking a long trip that involved uphill climb at 75 mph. I do think a checking/replacement of sensors may be in order, though.
Old May 30, 2004 | 03:09 PM
Ed's Avatar
Ed
How are your plug wires? The symptoms you describe are common after a long drive with borderline wires in a hot engine. Same with the distributor cap and rotor. years ago in my '87 Aerostar 3.0v6, I had the same sluggish perforformance after a long drive, especially in hot weather. After an overnight cool down, the van ran okay to work, etc. I'm not saying that is your problem, just something to check. Also, if you do replace the cap, rotor and wires, use a quality product. Motorcraft or similar. You will pay a little more ($65 for a wire set, as compared to $26) but it is worth every penny when you don't have to replace those cheaper quality parts. Good luck.
Old May 30, 2004 | 07:01 PM
razor_jim's Avatar
razor_jim
I believe I have had symptoms a while ago that were later described here as spark plug wire problems, so I'll definitely check that out. I guess they don't check those kinds of things when you get a tune-up. I just had the van tuned up about a month or so ago.
Old May 31, 2004 | 02:47 AM
Ed's Avatar
Ed
Jim, the thing too, is most plug wires look okay to the naked eye, yet inside the wire, it's deteriated badly. Heat is the enemy, so many heat soak conditions over time are the culprit. The heat these engines have to take is a torture chamber, that is why quality motor oil, oil filters, and the cooling system is very important on Aerostars. Good luck. If you do determine what was causing the sluggish performance when hot (after a long freeway run, etc.) please post, as I would be curious to learn what you found out. Peace...ED
BDFD
Mar 28, 2024 11:15 AM
Cameron Barentine
Sep 27, 2016 08:45 AM
Adamtgarner
1983 - 2012 Ranger & B-Series
Jun 17, 2016 07:02 AM
1998Ranger25L153CID
May 26, 2014 11:32 PM
DieselBeast01
24
Dec 15, 2009 08:12 PM
