replacing light behind speedometer
Old May 28, 2004 | 06:51 PM
harvey7212's Avatar
harvey7212
i have a 96 ford ranger and i was wondering how i can go about replacing the light behind the speedometer. i need to know how to remove the dash or whatever i have to remove to get to the light. thanks
Old May 28, 2004 | 10:07 PM
hreed's Avatar
hreed
The instrument cluster has to be removed. You should disconnect the neg bat terminal, then the pos terminal and wait 2 minutes because of the airbags. Pull the radio panel then get all the screws out for the cluster. It will come part of the way out. Then remove the speedo cable and electrical connectors. Replace all the bulbs while you are in there with the long lasting bulbs. It's not too difficult, except for the speedo cable. It's a printed circuit and somewhat fragile, so be gentle with it.
Old May 29, 2004 | 09:45 AM
Vin 95's Avatar
Vin 95
I think you have to pull the panel under the steering collum too.no screws,just push clips.
Old May 29, 2004 | 11:08 AM
BassGuy's Avatar
BassGuy
On a '96, you have to remove the black panel around the radio/AC/etc. Remove the panel below the steering column AND the metal plate underneath. Then you can start removing the instrument cluster. It's a pain... I've had to do it twice.
Luckily, there is no speedometer cable. It's all electronic.
astembridge
May 30, 2013 07:56 PM
marragtop
Mar 18, 2009 10:40 PM
chantilly bird
1997 - 2003 F150
Dec 22, 2003 05:00 PM
gibhart
Feb 20, 2003 08:24 PM
Demon83
Aerostar
Jul 1, 2002 06:49 PM
