speedometer cable
Old Feb 20, 2003 | 09:29 AM
gibhart's Avatar
gibhart
speedometer cable
I've got an '86 F250 with a skweaky speedometer cable. Feel pretty droky posting this question online but here it goes. How do you remove the cable from the speedometer? I've twisted on the white plastic nylon piece but it doesn't seem to want to budge.
Was thinking about just putting a light coating of white grease on the cable but otherwise does anyone have suggestion for a replacement cable?
Thanks in advance.
Mike
Old Feb 20, 2003 | 11:29 AM
Chuck 6083's Avatar
Chuck 6083
From: Where they take the census by counting the appliances on the front porch and multiplying by five
speedometer cable
Welcome to FTE Mike!
No question is dorky if you don't know. Everyone has to learn somehow.
Very simply, you dont twist. There is a notch or raised portion of the coupling on the side of the cable and you simply press the "notch", pull, and separate it from the back of the speedo head. It should come apart quite easily. If you have to use anything near force, you're doing it wrong.
Conversly, to re-install just slip it back on to the speedo head and push it on until it "clicks" (felt or audible).
You're done.
Welcome again!
Chuck
Old Feb 20, 2003 | 08:24 PM
steve83's Avatar
steve83
speedometer cable
This site shows it in detail. The owner's manual says lube the cable with (naturally ) Speedo Cable Lube PN:E6TZ-19581-A, or any lube meeting Ford spec ESF-M1C160-A. You can probably find something at a parts store.
Stevenbowman23
Mar 23, 2015 12:12 AM
cstapleton
16
Jun 27, 2011 11:32 PM
newblder
Sep 11, 2009 10:16 AM
hemiyota
May 6, 2006 06:56 AM
plilikoi
Bronco II
Feb 28, 2006 07:44 PM
